Results 1 to 4 of 4
Thread: Lisp Lisp path
    Full Member
    AutoCAD 2008
    May 2010
    48
    Default Lisp Lisp path
    Hey I have this problem.
    I use my LISP that imports data to a txt file.
    The problem is that the path where the record taken from another txt file.
    And I would like to save the data in a directory called Data just that:
    If the file is dwg eg C: \ fig \ something \ beam
    is that the data exported to the directory C: \ thousand \ cos \ data
    Can I do something like this?
    I read something about Dwgprefix, Dwgname, Dwgtitlet but I do not know how it linked with Lisp
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,743
    If you want to write to a new directory, you can create it using perhaps vl-mkdir, else if the directory exists, depending on the mode used with the open function, the file will be created automatically.
    I'm not sure I completely understand your query however.
    Lee Mac Programming
    Just another Swamper
    Full Member
    AutoCAD 2008
    May 2010
    48
    The point is that:
    I would like to check the path in which it is dwg file (sometimes in different places depending on the project)
    Saves a path to the variable cut for a number of characters, namely:
    If the path looks like C: \ Pro1 \ Fig \ 01.dwg after truncation would look like C: \ Pro1 \
    And now add to the path expression data. So the path looks like this: C: \ Pro1 \ Data \.
    (This exists). And further, this variable is used as the path to write to the data exported by LISP. I do not know how write properly but I hope that you understand
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,743
    Oh I see
    Certainly look into DWGPREFIX which will get you the filepath that the drawing is saved to.
    Then, you can concatenate the string data using the strcat function.
    Bear in mind that you need to use double backslashes to indicate a single backslash, as a single backslash indicates the beginning of an escape character sequence.
    I would think something like this:
    Code:
    (strcat (getvar 'DWGPREFIX) "Data\\")
    Lee Mac Programming
  1. a lisp to apply 3 different lisp to 3 obj types filtered from one selection
    By gilsoto13 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Nov 2009, 05:28 am
  2. Full path to Relative Lisp/VBA
    By Emily_83 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th May 2009, 11:48 am
  3. Lisp Call Lisp Problem
    By neekcotrack in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Aug 2008, 12:56 pm
  4. Path in LISP routines?
    By Kollargoll in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Sep 2007, 01:30 pm
  5. problem, trying to running a list of lisp from within a lisp
    By twind2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Aug 2007, 04:27 pm
