Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Forum Newbie
    AutoCAD 2009
    May 2010
    2
    Default Circles/arcs turning into straight/jagged lines
    I am having an issue with all my circles and arcs turning into straight line segments
    ex:
    a cirlce turns into a hexagon.
    Is there a command to fix this?
    Thank you!
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,581
    Quote Originally Posted by mccarthyk54751 View Post
    ex:
    Thank you!
    Usually either
    VIEWRES needs to be set higher, (or you just need to regenall)
    or
    SHADEMODE needs to be set to 2D
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    What about WhipArc?
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,076
    Or even perhaps a simple Regen.
  5. #5
    Super Member
    AutoCAD pre 2000
    Nov 2008
    577
    I got this problem too. It is noted in the BUG sheet mailed here years ago, and never completely resolved, in any version full or LT or whatever. You must be then working with a few polylines. We used to call this feature "Sucking In" as all the offending lines then go to inside of the curve.
    It does not happen if you EXPLODE the offending polyline, or do a quicky REGEN just after creating the work. If you do a few lines and then imediately exit the drawing, well look at it after your then come back or ship it off to another location. It all is changed. No amount of REGEN will fix it once it happens. One of my customers required me to do a quick regen befoe receiving any Autocad drawing via internet. Zip compressing does not fix it either.
    If the polyline is open ended (a non-circle) then often does not happen. I cut slots or fail to exactly link up every segmant of the polyline (on purpose) to avoid the sucking in feature.
    Wm.
  6. #6
    Super Member MikeScott's Avatar
    MikeScott's Computer Details
    XP Pro
    Dell Precision T3400
    2.67 gigahertz Intel Core2 Duo
    2046 Mb
    NVIDIA Quadro NVS 290/ 256MB DDR2
    ST3500418AS/ 500gb (450gb free)
    DELL G2410 (24.0"vis)
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    tesselation settings?
    Depends where you're getting the problem.. is it a viewing/plotting issue, an export to DXF issue, or a rendering issue?
  7. #7
    Forum Newbie
    AutoCAD 2009
    May 2010
    2
    It displays with the straight lines in model space and in paper space. I just need them to be curved in order to plot.
    I did the REGENALL and this helped a lot, but they are still a little jagged.
  8. #8
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,723
    Then that is probably just your display settings. That is not the same as the 'sucking in' issue. What's happening is AutoCAD is saving memory space for execution and point coordinates locations until you stop drawing stuff and do a regen all.
    Go to Tools > Options > Display > Display Resolution.
    I set my Arc and Circle smoothness to 1000 and my polyline curve segments to 8 and I don't have a big issue with the drawing appearance after a regen.
    Also, make sure your screen resolution in "WINDOWS" is set to the correct one per your monitor's capabilities.
    None of my above has any effect on plotting, the objects will plot smooth with any plot quality level better than draft.
    Last edited by Dana W; 10th May 2010 at 05:00 pm. Reason: cuz my spillcheeker is broked!
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  9. #9
    XP Pro
    2046 Mb
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    yeah.. Dana's right. When you print, they'll correct themselves.. that's just a display issue.
  10. #10
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by MikeScott View Post
    WhipArc will correct plotting problems. I had to fix this in Civil 3D (pipes were displaying at polygons instead of ellipses).
    DropBox
  1. Fire Engine Turning Circles
    By nman in forum AutoCAD General
    Last Post: 26th Mar 2010, 03:28 am
  2. Arcs and Circles
    By aldawn in forum AutoCAD Beginners' Area
    Last Post: 19th Nov 2009, 11:34 am
  3. Smooth out arcs and circles in 3ds
    By nocturne00 in forum 3D Modelling
    Last Post: 3rd Aug 2009, 06:08 pm
  4. Help w/ Arc's, Circles, mine look jagged
    By TREX in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2009, 01:17 am
  5. arcs print jagged
    By phonhead in forum AutoCAD Drawing Management & Output
    Last Post: 9th Aug 2007, 09:34 pm
