Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 65
    Junior Member
    Mechanical 2009
    May 2010
    23
    Default Scale in AutoCad
    Hello,
    i have a question regarding the scale option in AutoCad. If the Scale you wanted to set was 1:150 how would you go about doing this?
    Cheers.
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    FjÀrdhundra, Sweden
    5,148
    Scale is something you set on your viewport in most cases. When you draw, you always draw in 1:1 scale.
    MTJIGSTRING = BAZINGA
    Junior Member
    Mechanical 2009
    May 2010
    23
    so i take it in most cases measurement is done in mm? then u just set the scale to whatever size you need?
    cheers
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Draw everything FULL size in model space.
    The Scale command is for enlarging or shrinking an object. It has nothing to do with the "scale" of the drawing.
    After completing your model space drawing switch to a Layout. Layouts give us access to paper space. In paper space we create viewports. Viewports are windows that allow us to see objects we created back in model space. It is the viewport that a scale is applied to.
  5. #5
    Junior Member
    Mechanical 2009
    May 2010
    23
    ahh it all makes sense now.
    thanks very much
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    It does? Then could you explain it back to me?
  7. #7
    Junior Member
    Mechanical 2009
    May 2010
    23
    am i right in saying though if u are looking at a drawing (not a cad drawing) and it has a scale of 1:150 and you were to draw this in model space if the length of the drawing was say 100 m you would draw the length in model space as 100x150 correct?
    this might start to get confusing
  8. #8
    Full Member Seath's Avatar
    Seath's Computer Details
    Mricrosoft Windows XP Professional SP3
    Dell Precision T3400
    Intel Core 2 Quad CPU Q6600 2.40GHz
    4.00GB
    NVIDIA Quadro FX 570
    Dell 2408 WFP 24"
    Manufacture
    Seath's Discipline Details
    Manufacturing, Design, Project Managment
    Manufacture
    AutoCAD 2013
    Jan 2008
    Atlanta, Georgia
    47
    If the line measures 100mm at 1:150 (assuming that you have a hand scale for 1:150 to measure the line) than you draw the line as 100mm in model space. If the hand scale you are using is only 1:1 and the line measures 100mm than yes you would scale the line up to get the actual length of the line you want to draw in model space.
  9. #9
    Junior Member
    Mechanical 2009
    May 2010
    23
    still confused.
    basically am drawing a layout of a boat in autocad the scale is 1:150. If i measure with my ruler the bit of the boat i want to draw it is 130mm length on the bit of paper. so does that mean i draw 130 mm line for the length in model space?
  10. #10
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by Frazer1987 View Post
    still confused.
    You do not scale the boat, draw it 1:1 draw it the way it is in the real world.
    Once you get it drawn representing the real world come back and ask how to get it on a sheet of paper.
  1. Scale List Cleanup Utility for AutoCAD 2008 and AutoCAD 2009
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 24th Apr 2008, 06:00 pm
  2. Improting an autocad file - scale way off
    By andyboy in forum SketchUp
    Last Post: 13th Feb 2007, 09:39 pm
  3. Scale, Autocad 2006
    By Davelee01 in forum AutoCAD Beginners' Area
    Last Post: 8th Nov 2005, 09:16 pm
  4. 1:1 SCALE IN AUTOCAD 2000
    By dangermouse in forum AutoCAD Beginners' Area
    Last Post: 24th May 2004, 10:26 pm
  5. AutoCAD 2002 - Scale
    By qfoa03 in forum AutoCAD Beginners' Area
    Last Post: 27th Jan 2003, 02:26 pm
