Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 65
  1. #11
    Junior Member
    Mechanical 2009
    May 2010
    23
    the drawing of the boat is already done and finished it is sitting in front of me just now on a piece of paper, it was not done using autocad.
    I am only copying a section of the boat layout into autocad so as i said in question above do i draw a line that measures 13 mm with a ruler or do i need to multiply that by 150 to give me the actual length since the boat is already scaled at 1:150
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,643
    You have a drawing of a boat that has no dimensions but it has a scale?
    Then you are going to have to measure first and do the math based on the scale of the drawing. That assumes the drawing wasn't enlarged or reduced to begin with in which case whatever you arrive at isn't going to be correct.
  3. #13
    Junior Member
    Mechanical 2009
    May 2010
    23
    ok thanks.
    i also presume that everything needs to be converted in mm for autocad?
  4. #14
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,083
    If you have a line that measures 13mm on your scale drawing (post #11), then you would draw a line 1950 units long in AutoCAD.
    If you had a line 130mm long on your scale drawing (post #9), then you would draw a line 19500 units long in AutoCAD.
    AutoCAD draws in drawing units which you can call what you like, but in this case millimetres.
  5. #15
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Quote Originally Posted by Frazer1987 View Post
    ok thanks.
    Did you start from the Imperial (inch) template or did you start from the Metric (mm) template?
  6. #16
    Super Member
    AutoCAD LT 2014
    Sep 2008
    545
    Sorry to interrupt, but do you set the scale of the plot in the viewport and the page setup manager?
    Glenn
    2009LT
  7. #17
    Junior Member
    Mechanical 2009
    May 2010
    23
    hit another snag now, if u draw a line in model view that is 19500 mm long how do zoom out enough that u can see all of the line as it wont let me go any firther than i already have.
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,643
    Zoom > Extents.
    Please tell us what template you are using. It does make a difference.
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,643
    Quote Originally Posted by gsksun4 View Post
    Glenn
    2009LT
    Who is this question directed at?
  10. #20
    Super Member
    AutoCAD LT 2014
    Sep 2008
    545
    Any one of the above. I'm doing the tutorial on viewport plotting and getting confused. Now there's setting scale in the viewport, setup mgr, and plot manager. She say's though, in the plot tool it should always be 1:1, and I know to set the scale in the viewport. I didn't mean to hijack the thread though. Sorry to interrupt.
  1. Scale List Cleanup Utility for AutoCAD 2008 and AutoCAD 2009
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 24th Apr 2008, 06:00 pm
  2. Improting an autocad file - scale way off
    By andyboy in forum SketchUp
    Last Post: 13th Feb 2007, 09:39 pm
  3. Scale, Autocad 2006
    By Davelee01 in forum AutoCAD Beginners' Area
    Last Post: 8th Nov 2005, 09:16 pm
  4. 1:1 SCALE IN AUTOCAD 2000
    By dangermouse in forum AutoCAD Beginners' Area
    Last Post: 24th May 2004, 10:26 pm
  5. AutoCAD 2002 - Scale
    By qfoa03 in forum AutoCAD Beginners' Area
    Last Post: 27th Jan 2003, 02:26 pm
