Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 65
  1. #21
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    For the best results...
    Model space: Draw full size without a doubt. Do not scale anything unless you are meaning to enlarge or reduce the size of an object.
    Viewports (in Layout): User's choice. The sky's the limit. Don't like the scales AutoCAD gives you create some of your own and add them to the scale list.
    Layout: 1:1 no question about it. Makes printing/plotting a whole lot simpler.
    But I'm sure you knew all this already you sly dog you.
  2. #22
    Junior Member
    Architecture 2010
    May 2010
    12
    Wink
    You were rite that u should make a line of 130mm (on paper) as 130x150=19500mm on model space. Whwn you will print then you should scale the print at 1:150, it will gives you the size exactly tht you got on paper. you have the rite tech in your mind and that was rite!
  3. #23
    Junior Member
    Architecture 2010
    May 2010
    12
    Smile
    You were rite tht you can make a line of 130mm as 130x150=19500mm. If u want to make line of whatever length on paper, just multiply that length to your scale in model space of autocad.
  4. #24
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Quote Originally Posted by Frazer1987 View Post
    .. can see all of the line as it wont let me go any firther than i already have.
    In addition to z a and re I would turn Limits off (please tell me you aren't using grid, if so, turn that off as well).
  5. #25
    Super Member
    AutoCAD LT 2014
    Sep 2008
    545
    Not as sly as you think, I'm struggling with the viewport thing. I know how to create a viewport, I've done that many times, but it was for 1 viewport for the entire drawing. It's isolating an area and plotting that area to scale I'm having trouble with. I'm trying to follow that tutorial where the lady takes you through it step by step, but have problems. One of which is not getting back into plain old model space without view setups. I'll have to try it again when I have more time here at work.
  6. #26
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    That lady? You mean Lynn Allen?
    Getting in and out of model space and your layout can be accomplished in a couple of ways.
    So, you want to create a layout with multiple viewports yet only plot what is showing in one of them?
  7. #27
    Super Member
    AutoCAD LT 2014
    Sep 2008
    545
    I've never isolated only one small part of a drawing in a viewport. I know how to create the viewport, I can't get that part to print out. At all. I wanted to test plotting one small area in that viewport to scale. I don't know the ladies name, she narrates thatm tutorial Tankman posted a link to in ther dimensioning in isometric thread.
    http://www.andrew.cmu.edu/course/48-...iles/frame.htm
  8. #28
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    One of the neat things about creating a viewport is that you can isolate that one small part of the drawing and give it a larger scale so the "detail" can be seen. I would have thought you had experimented with that capability already. If it is just that one viewport you want to print for some reason use the Window option but don't forget it still has to fit on the paper you selected and you should still plot 1:1 since you are doing it from within a layout.
  9. #29
    Junior Member
    Mechanical 2009
    May 2010
    23
    how do you turn limits off so you can see all of your drawing in model space?
  10. #30
    Senior Member sparkyuk's Avatar
    sparkyuk's Computer Details
    Windows 7
    AutoCAD 2010
    Jan 2007
    UK
    365
    type Z then enter, then E enter you will see all your drawing
  1. Scale List Cleanup Utility for AutoCAD 2008 and AutoCAD 2009
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 24th Apr 2008, 06:00 pm
  2. Improting an autocad file - scale way off
    By andyboy in forum SketchUp
    Last Post: 13th Feb 2007, 09:39 pm
  3. Scale, Autocad 2006
    By Davelee01 in forum AutoCAD Beginners' Area
    Last Post: 8th Nov 2005, 09:16 pm
  4. 1:1 SCALE IN AUTOCAD 2000
    By dangermouse in forum AutoCAD Beginners' Area
    Last Post: 24th May 2004, 10:26 pm
  5. AutoCAD 2002 - Scale
    By qfoa03 in forum AutoCAD Beginners' Area
    Last Post: 27th Jan 2003, 02:26 pm
