mdp198 Posted May 14, 2010 Share Posted May 14, 2010 Hello, I am working in AutoCAD 2008 3D and wonder if anybody might be able to help with an issue I seem to be having with my materials. I have applied a general default semi-gloss paint material (white) to parts of my model. I want to apply, sun and shadowing and create somewhat of an environment. I am able to do this except for two things. 1. When I turn on the sun/shadow conditions (keeping "viewport lighting mode:user sunlight/illumination off) my materials looks fine. However the shadow will not move the change in time. 2. When turning on the "viewport light mode:user sunlight/illumination" the shadow moves and looks great, but my White paint color does not look so white. I have experimented with the material properties conditions, and the white looks almost blinding in some instances in the preview but not in the actual view for some reason. I have attached two screenshots in the previous order. Thanks Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 14, 2010 Share Posted May 14, 2010 Are you using true white RGB 255,255,255 or are you using Autocad's color #7 white? Quote Link to comment Share on other sites More sharing options...
mdp198 Posted May 14, 2010 Author Share Posted May 14, 2010 its actually 242,242,242 from the "true color" scale. No reason why that specific color just want a "white". Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 14, 2010 Share Posted May 14, 2010 I think your key is going to be to add a light and do some experimenting with the position. Quote Link to comment Share on other sites More sharing options...
mdp198 Posted May 14, 2010 Author Share Posted May 14, 2010 After playing with the sun properties, i believe the intensity factor needed to be changed to lighten the whole scene. I will also try with inserting a light. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
fahim108 Posted May 15, 2010 Share Posted May 15, 2010 Render the scene, the second viewport is correct. The tint that's bothering you is basically because of the default sun color. AutoCAD uses a somewhat yellowish sun (which is alright), you don't need to change it. Simply render the scene and you'll understand. Use LIGHTINGUNITS - 2 and don't modify the default intensity factor... it'd burn the windmill ... Quote Link to comment Share on other sites More sharing options...
