Ribbon / Table edit toolbar issue
I've grown to be quite fond of the ribbon, but ever since I moved to it, the toolbar that pops up above a table whenever you select a cell is gone. If I close the ribbon, then it works. I would like to have it pop up even when the ribbon is open, and for autocad to stop loading the contextual tab for tables. Can someone point me in the right direction? I poked around the cui editor and can't seem to find the right thing to do... Thanks!
Bumpity for me. Here is a visual reference, in case it helps :(
Upper picture is the tab that opens for tables when I have the ribbon open. Lower picture is the toolbar that appears above the table when the ribbon is closed. I would like to have my ribbon open, but have the toolbar appear above the table.
You can add tool bars below the ribbon.
This what you mean?(2010 version)
At times this is quicker for me.8)
Found it,
COMMAND:TABLETOOLBAR : 1
0 The Table toolbar is never displayed.
1 The Table toolbar is displayed upon selection of a table cell.
2 The Table toolbar is not displayed when the ribbon is turned on.
