drifter15 Posted May 17, 2010 Share Posted May 17, 2010 Hi, I am working on a project for a subject. Yesterday I was working on the drawing and reaching final stage, it was about to complete. It had a lot of parts and each part is in a separate layer. It was late in the night , I saved my work and closed AutoCAD (2008 ). Today I came to continue, but I found only two parts. The rest are gone!! The layers are still there, but they are empty. That what I found I tried to reload it more than one time, but useless. How can I recover my drawing? I don't have a backup drawing, only that one. and it is due tomorrow Why did that happen?!! can I get it back? Thanks alot Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2010 Share Posted May 17, 2010 Load the drawing. Switch to a 2D wireframe view. What do you see? Quote Link to comment Share on other sites More sharing options...
drifter15 Posted May 17, 2010 Author Share Posted May 17, 2010 I loaded and reloaded the drawing many times, changed the views, the visual style. I pressed ctrl+A to select all the parts , but only two parts are there, the ones shown in the figure. I was working with AutoCAD 2008. I opened it with AutoCAD 2010 but the same problem is there. I searched in the temp folder for any backup , but found nothing!!! It is the first time I see such a problem! Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2010 Share Posted May 17, 2010 Do a search of your entire hard drive for the file name and use the wildcard extension. Example: mydrawing.* This will find any instances of the dwg and/or bak files that are on your hard drive. You do have AutoCAD create backup files when you save right? Quote Link to comment Share on other sites More sharing options...
drifter15 Posted May 17, 2010 Author Share Posted May 17, 2010 Thanks a lot ReMark. AutoCAD does create backup files, and I tried searching my hard drive for any related files, unfortunately all of them are recent shortcuts and backups of the new dwg file, the one with missing parts!! I tried to open the file in another computer with AutoCAD 2007 but again same results!! It is really strange, could it be from the PC or from the software?! I have an old copy of the design but it lacks many modifications, it seams that I will repeat all the work on the old copy unless there is a solution! Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2010 Share Posted May 17, 2010 Move the existing drawing file to a temp folder. Rename the most recent bak file to dwg and use that file to reconstruct your model. I don't know what caused this to happen but I do know that you need to save on a more frequent basis. What is AutoSave set to? You should also get yourself a flash drive and save a copy (as insurance) to it too. Quote Link to comment Share on other sites More sharing options...
drifter15 Posted May 17, 2010 Author Share Posted May 17, 2010 It did not work too!! The size of the backup file was 13,108 kb. I changed it to name.dwg and opened it, it opened with lost parts, when I saved it again the file size became 1,906 kb. Thanks for ur replys, you suggested many solutions, thanks alot I'll savce more frequently. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2010 Share Posted May 17, 2010 I'm sorry to hear that. In the past I too lost a couple of very valuable drawings and learned the hard way to save often and to keep multiple copies of my files. I save to my hard drive, place a copy on the network, backup daily to a flash drive and weekly to a DVD. Some people use external hard drives, Iomega zip drives or even tape drives. One last question. AutoCAD did not crash did it? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 17, 2010 Share Posted May 17, 2010 There is a bug in AutoCAD since 2007 that causes lost solids. Turn off the variable solidhist in your template. I have been able to recover some lost dwg solids using Inventor. Attach your dwg file here. Quote Link to comment Share on other sites More sharing options...
drifter15 Posted May 18, 2010 Author Share Posted May 18, 2010 One last question. AutoCAD did not crash did it? No it did not crash. I had another copy , but it it lacked most of the modifications, so I worked on it and re-did most of the worked. But the time lost can't come back. There is a bug in AutoCAD since 2007 that causes lost solids. Turn off the variable solidhist in your template. I have been able to recover some lost dwg solids using Inventor. Attach your dwg file here Thanks JD Mather, did they fix it in 2010? where can I find " solidhist" Here is the dwg and the back up file ت�*ميل الملفwheelchair.rarمن هنا"]ت�*ميل الملف wheelchair.rar من هنا I hope the link works Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 18, 2010 Share Posted May 18, 2010 Solidhist can be accessed via the command line. There are only two settings. "0" and "1". Further info available in AutoCAD Help file. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 18, 2010 Share Posted May 18, 2010 Solidhist (brep) will not fix after the fact. It was not fixed in 2010 (they would not even admit to me there was a problem until 2010). I don't know about 2011. I am on vacation this week, so it might be a while till I have time to look at your file (since you posted an rar rather than a zip). Quote Link to comment Share on other sites More sharing options...
