+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Full Member
    Using
    Civil 3D 2011
    Join Date
    Nov 2009
    Posts
    68
    Default Drawing 3D general question
    I am about to start another drawing for practice and was thinking of drawing my desk phone. It looks complicated with many curves on all sides (I don't think there is a straight edge anywhere-really).
    My question is, what is the best way to approach something like this (is there a best way)? From the front and then extrude and cut or build up with small parts unioned together? From the top view?
    Each side is complicated and different from each other, so extruding only gives a solid, but not what is needed. I was also considering drawing a model car (matchbox), and they have the same issues; curves everywhere. I can mirror a lot, but will still need to add to it.
    I'm not sure if this is too complicated of a project to take on. Classes for my second course just ended, so I am on my own. Maybe I should keep practicing on easier drawings.
  2. #2
    Full Member
    Computer Details
    drifter15's Computer Details
    Computer:
    Dell inspiron 1525 - laptop
    Using
    AutoCAD 2008
    Join Date
    Sep 2009
    Location
    Oman
    Posts
    38
    Default
    You can use othe 3d commands rather than extrude and subtract.
    Try using loft command or sweep command.
    Draw cross sections of the object you want to model and loft them.
    It is easy and powrfull command.
  3. #3
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,144
    Default
    Moving to a 2010 or 2011 product would give you access to a new feature called Free Form Design. FFD makes use of enhanced mesh objects.
  4. #4
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,906
    Default
    See the tutorials in my signature.
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #5
    Full Member
    Using
    Civil 3D 2011
    Join Date
    Nov 2009
    Posts
    68
    Default
    Ok, I will give all those ideas a try; and I won't give up. You may here from me again as I get going, but hopefully not too much.
Similar Threads
  1. x reference general question
    By addesigns in forum AutoCAD General
    Last Post: 3rd Dec 2009, 06:17 pm
  2. Raster Design General Use Question
    By AQucsaiJr in forum AutoCAD General
    Last Post: 21st Sep 2009, 06:59 pm
  3. General question regarding print drivers...
    By StykFacE in forum AutoCAD Drawing Management & Output
    Last Post: 26th Sep 2006, 11:50 pm
  4. autoLISP general question
    By X in forum AutoCAD Beginners' Area
    Last Post: 1st Aug 2006, 08:05 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
