Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 41
  1. #11
    Full Member Andrew_Amp's Avatar
    Andrew_Amp's Computer Details
    XP
    AutoCAD 2007
    May 2010
    Stansted, Essex, UK
    29
    Update...
    The lofted shape sadly was dimensionally inaccurate so i am back to where i started.
    On the plus side i have now looked at the wireframe again (one of my elipses was actually a spline on the model - the lofted shape was all pellipses when i put the two together the edges didn't marry up) and have redefined my perimiter shape with pellipses - but it won't loft using either of the guides now (although it will if i choose either one as a path oddly).
    Update...
    Solved the lofting issue - have the surface and it is dimensionally correct now
    Any ideas how i achieve the 35mm thickness from here?
  2. #12
    XP
    AutoCAD 2007
    May 2010
    Stansted, Essex, UK
    29
    Update...
    Thanks to the help so far, it currently looks like this:
    Have the first surface in place, mirrored to infill both sides of the vault. However it is still just a surface and needs to be offset into the interior space to provide a 35mm thick solid. At the moment i have hit a wall here, all of my attempts have failed and i am out of ideas.
    I am feeling very out of my depth here...
  3. #13
    Super Member fahim108's Avatar
    fahim108's Computer Details
    Windows XP Professional
    HP Pavilion dv5000
    Architectural
    fahim108's Discipline Details
    Architect
    Architectural
    AutoCAD 2016
    Apr 2006
    Mumbai, India
    501
    You are trying for a solid model or a surface model here?
  4. #14
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Quote Originally Posted by Andrew_Amp View Post
    The only Surface => Solid option available to vanilla AutoCAD is the THICKEN command; it doesn’t have the ability to stitch together individual surfaces. If you’re still getting the “Object intersects itself. Surface cannot be thickened with specified value” warning perhaps you could try a smaller value, then SolidEdit-Face-Offset.
  5. #15
    XP
    AutoCAD 2007
    May 2010
    Stansted, Essex, UK
    29
    Quote Originally Posted by fahim108 View Post
    I would like a solid model, and have tried lofting a shape with thickness, but the thickness varies over the curve - ultimately i need to produce some formwork so the goal of the project is to define the shape (including thickness) then design supporting ribs in timber to produce the mould. So it is critical that a constant 35mm thickness is achieved.
    The surface as drawn currently is my best effort so far, but i am on a steep learning curve here - although i have been using AutoCAD since Release 10, it has been in general 2D stuff with my 3D experience being limited to far simpler shapes.
    Quote Originally Posted by SEANT View Post
    Will give it a go and report back...
  6. #16
    XP
    AutoCAD 2007
    May 2010
    Stansted, Essex, UK
    29
    QUOTE: Select faces or [Undo/Remove]:
    A 3D solid must be selected.
    No solids detected.
    Very odd...
  7. #17
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Have you tried the THICKEN command with a smaller value, 1 mm perhaps. If there are no proprietary concerns, post the outline geometry. A better demo will stimulate better suggestions.
  8. #18
    XP
    AutoCAD 2007
    May 2010
    Stansted, Essex, UK
    29
    Tried thicken with smaller values (went down to -.01) with no success.
    I have attached an earlier draft which should give you the geometry - hopefully this will be useful.
  9. #19
    XP
    AutoCAD 2007
    May 2010
    Stansted, Essex, UK
    29
    OK, the game has moved on a bit - i tried slicing the surface and it won't let me - this means, i think that the surface is not going to do what i want it to either. I am back now looking at a solid and the loft command again - at least, even with a sold that has a varying thickness, i can slice it - if i can slice it i can then draw over the top arc and then i can offset the line to get my 35mm thickness - this will set out the top of the formwork ribs so it should get me to the finishing post (if i can get the loft command to work again - seem to have the same issue as before, won't loft using both guides).
    What this means is that i will end up with a 3D model that is known to be wrong, but knowing where it is wrong will allow me to compensate to produce the formwork. At least that's the theory.
    Ideally the 3D model would be right, but either CAD isn't capable or (more likely) i don't have the skills set to do this - i'm therefore trying to think outside the box, trying to achieve the goal without producing a dimensionally accurate model. It's a risky strategy, but i'm all out of ideas here.
  10. #20
    XP
    AutoCAD 2007
    May 2010
    Stansted, Essex, UK
    29
    Minor update - solved lofting to produce a solid. The thickness issue has reappeared, but i have been able to slice the model and i therefore think i can overcome this by tracing over the top arc and then offsetting this new line 35mm to give me the under surface at this point.
    Now working on the other surface... Model currently looks like this:
  1. vault library
    By silviu30 in forum CAD Management
    Last Post: 26th Jan 2010, 04:02 pm
  2. Vault thumbnails
    By Hickoz_bro in forum Autodesk Inventor
    Last Post: 14th Mar 2008, 08:33 am
  3. Source control - Vault
    By DavidB in forum AutoCAD Drawing Management & Output
    Last Post: 16th Dec 2007, 10:33 am
  4. Vault 5 Install
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 21st Feb 2007, 10:40 pm
  5. do i HAVE to install the vault?
    By Bloodwig80 in forum Autodesk Inventor
    Last Post: 12th Nov 2005, 11:24 am
