VB.NET - Export to DXF Help (Revit)
harrison-matt
Hey,
Does anyone know the format or syntax of exporting to dxf in VB.Net?
Autodesk.Revit.CADExportOptions
Or just some help on VB.Net will work!
Thanks,
Matt
  • 6 years later...
I'm not sure about Revit but with most Autodesk products you can use something like the following.
Call oDrawDoc.SaveAs(oPath & "\PDF\" & oName & ".pdf", True)
