Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 23
  1. #11
    Senior Member lfe011969's Avatar
    AutoCAD 2009
    Apr 2010
    Newport News, VA
    157
    Is it possible to create zones based on, let's say, rectangular coordinates where when a field is inserted into a certain area or zone, the field gets updated to match it's location?
    I've attached a sample drawing format where I show lines splitting up the drawing into 48 sections. On SH 02 of this drawing I show the text I'd like to include a field in that would update the last two characters (the vertical and horizontal markers) of the top line.
    This is probably not the way to do it but I was thinking along the lines of having to set 48 separate variables in a lisp routine to each section's rectangular cross-section coordinates. Then when a piece of MTEXT is placed on the drawing, the lisp would detect within which section it has been placed in and update the field accordingly.
    Would appreciate suggestions. Thanks.
  2. #12
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,798
    You dont need 48 checks just compare Y value of point for A-F and X for 1-8 string them together.
    something like If x = 101-200 etc then B (cond (and (> x 101.0) (< x 200.0 )) (setq vert "B")
    2 cond checks
  3. #13
    AutoCAD 2009
    Apr 2010
    Newport News, VA
    157
    Thanks BigAl. I'll see what kind of code I can hammer out this morning based on your suggestion.
  4. #14
    Senior Member stevesfr's Avatar
    stevesfr's Computer Details
    Vista <ugh>
    HP Pavilion
    Dell Trinitron
    AutoCAD 2008
    Jan 2009
    Central Illinois, USA
    270
    Program will export to Excel perfect, but will not put coords into table within dwg. Using A2008.
    help !
    s
  5. #15
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,816
    Whose code are you referring to Steve?
    Lee Mac Programming
    Just another Swamper
  6. #16
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,666
    Quote Originally Posted by asos2000 View Post
    I think that he wants the lisp to be at this sequance
    - Pick a point
    - Insert a point and a sequencial number
    - at end create a table has the point number and N and E for
    So See this
    Code:
    ;; local defun
    (defun make-tablestyle ( name desc txtstyle h1 h2 h3 / tblstyle adoc)
      (or (vl-load-com))
      (setq
        tblstyle (vla-addobject
          (vla-item (vla-get-dictionaries
                  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
               "Acad_Tablestyle"
          name
          "AcDbTableStyle"
      (setq acmCol (vla-getinterfaceobject
            (strcat "AutoCAD.AcCmColor."
             (substr (getvar "ACADVER") 1 2))))
      (vla-put-name tblstyle name)
      (vla-put-headersuppressed tblstyle :vlax-false)
      (vla-put-titlesuppressed tblstyle :vlax-false)
      (vla-put-description tblstyle desc)
      (vla-put-flowdirection tblstyle 0)
      (vla-put-bitflags tblstyle 1)
      (vla-put-horzcellmargin tblstyle (/ h3 5))
      (vla-put-vertcellmargin tblstyle (/ h3 5))
      (vla-settextstyle tblstyle 7 txtstyle)
      (vla-settextheight tblstyle 1 h3)
      (vla-settextheight tblstyle 4 h2)
      (vla-settextheight tblstyle 2 h1)
      (vla-setrgb acmCol 204 102 0)
      (vla-setgridcolor tblstyle 63 7 acmCol)
      (vla-setgridvisibility tblstyle 63 7 :vlax-true)
      (vla-setgridlineweight  tblstyle 18 7 aclnwt009)
      (vla-setgridlineweight tblstyle 45 7 aclnwt050)
      (vlax-release-object acmCol)
    ;; local defun
    (defun draw_table (ins_point title     header_list
                                    table_data
                                    /         acmcol
                                    acsp      adoc
                                    axss      cnt
                                    col       columns
                                    dht       lst_count
                                    objtable  row
                                    rows
      (if (< (atof (getvar "ACADVER")) 16.0)
      (alert "This routine will work\nfor versions A2005 and higher")
      (alert "\tBe patience\n\tWorks slowly")
      (or (vl-load-com))
      (or adoc
      (vlax-get-acad-object))))
      (or acsp (setq acsp (if (= (getvar "TILEMODE") 0)
      (vla-get-paperspace
      adoc)
      (vla-get-modelspace
      adoc))
      (make-tablestyle "Point Data" "Symbol table" "Standard" 10.0 10.0 12.0)
      (setq dht (getvar "dimtxt")); text height, change by suit
      (setq lst_count nil)
    (setq columns  (length (car table_data))
     rows  (length table_data)
    (setq objtable (vlax-invoke
       acsp
       'Addtable
       ins_point
       (+ 2 rows)
       columns
       ;; rows height (change by suit):
       (* dht 1.667);28
       ;; columns width (change by suit):
       (* dht 8.333);50
      (vla-put-regeneratetablesuppressed objtable :vlax-true)
      (vla-put-layer objtable "0")
      (vla-put-titlesuppressed objtable :vlax-false)
      (vla-put-headersuppressed objtable :vlax-false)
      (vla-put-horzcellmargin objtable (* dht 0.5))
      (vla-put-vertcellmargin objtable (* dht 0.5))
      (vla-settextstyle objtable 2 "Standard")
      (vla-settextstyle objtable 4 "Standard")
      (vla-settextstyle objtable 1 "Standard")
      (vla-setrowheight objtable 2 (* dht 1.5))
      (vla-setrowheight objtable 4 (* dht 1.25))
      (vla-setrowheight objtable 1 (* dht 1.25))
      (vla-settextheight objtable 2 (* dht 1.25))
      (vla-settextheight objtable 4 dht)
      (vla-settextheight objtable 1 dht)
      (vla-put-colorindex acmcol 256)
      (vla-put-truecolor objtable acmcol)
      (vla-setcolumnwidth objtable 0 (* dht 10))
      (vla-setcolumnwidth objtable 1 (* dht 15))
      (vla-setcolumnwidth objtable 2 (* dht 15))
      (vla-setcolumnwidth objtable 3 (* dht 15))
      (vla-put-colorindex acmcol 2)
      (vla-settext objtable 0 0 title)
      (vla-setcelltextheight objtable 0 0 (* dht 1.5))
      (vla-setcellcontentcolor objtable 0 0 acmcol)
      (vla-put-colorindex acmcol 102)
      (setq col 0
     row 1
      (foreach a header_list
        (vla-settext objtable row col a)
        (vla-setcelltextheight objtable row col (* dht 1.25))
        (vla-setcellcontentcolor objtable row col acmcol)
        (setq col (1+ col))
    (vla-put-colorindex acmcol 40)
    (setq  row 2 col 0)
      (setq cnt 1 row 2)
      (foreach i table_data
      (setq col 0)
      (foreach a i
        (if (= col 0)
        (vla-setcellalignment objtable row col acMiddleLeft))
           (vla-settext objtable row col (rtos a 3 2))
        (vla-setcellalignment objtable row col acMiddleCenter))
        (setq col (1+ col)))
        (setq row (1+ row))
      (vla-put-regeneratetablesuppressed objtable :vlax-false)
      (vl-catch-all-apply
        (function
          (lambda ()
       (vla-clear axss)
       (vla-delete axss)
       (mapcar 'vlax-release-object (list axss objtable))
      (vla-regen adoc acactiveviewport)
      (alert "Done")
    ;; local defun
    (defun draw_textfromlist (data_list txt_height / )
        (or (vl-load-com))
        (or adoc
      (vla-get-paperspace
      adoc)
      (vla-get-modelspace
      adoc))
        (mapcar (function (lambda(x)
                                 (vlax-invoke acsp 'AddText
                                                (car x)
                                                (list (cadr x)(+ (caddr x)(* txt_height 0.785))(last x))
                                                txt_height)))
                 data_list
    ;; main part
    (defun C:PNT (/ ans fd fname lbl loop num pfx pt pts)
    (initget "Y N")
    (setq ans (getkword "\nDo you want to add prefix? (Y/N) <Y> : "))
    (if (not ans)(setq ans "Y"))
      (if (eq "Y" ans)
          (setq pfx (getstring T "\nEnter the prefix to add: ")))
      (setq num (getint "\n Enter the initial number <1> : "))
        (if (not num)(setq num 1))
        (setq pt (getpoint "\nDigitize the first point :")
       lbl (if pfx (strcat pfx (itoa num))(itoa num))
     pts (cons (cons lbl pt) pts))
      (setq num (1+ num))
        (while
        (setq pt (getpoint "\nDigitize the next point [hit Enter to exit] :" pt))
        (if (null pt)(setq loop nil))
        (setq lbl (if pfx (strcat pfx (itoa num))(itoa num)))
        (setq  pts (cons (cons lbl pt) pts))
        (setq num (1+ num))
        (setq pts (reverse pts))
        (draw_textfromlist pts  (getvar "dimtxt"));<-- text height, change by suit
      (initget "E A")
      (setq ans (getkword "\nDo you want to export point to Excel Or draw Acad table? (E/A) <E> : "))
      (if (not ans)(setq ans "E"))
      (if (eq "E" ans)
      (setq fname (getfiled "* Set Name Of New Excel File *" "" "xls" 1))
      (setq fd (open fname "w"))
      (princ "Point label\tX coord.\tY coord.\tZ coord.\n" fd)
      (foreach i pts
        (princ (strcat (car i) "\t"
         (rtos (cadr i) 3 2) "\t"
         (rtos (caddr i) 3 2) "\t"
         (rtos (last i) 3 2) "\n")
        fd)
      (close fd)
              (setq ipt (getpoint "\nPick insertion point of table: "))
              (draw_table ipt "Title goes here" '("Point No." "X coord." "Y coord" "Z coord.") pts)
    (princ "\n\t\t***\tType PNT to export points to Excel or to Acad table\t***")
    A very great lisp Mr. Asos2000
    I liked a lot..... I recommend everybody to try it ....
  7. #17
    Vista <ugh>
    HP Pavilion
    Dell Trinitron
    AutoCAD 2008
    Jan 2009
    270
    Quote Originally Posted by Lee Mac View Post
    Asos program. Sorry guys, I thought my reply would "grab" the proper post.
    As I stated, results to Excel are perfect. When choosing Acad option, the table is created, but it is void of any "text" (coordinates). Lee, yours works fine.
    Steve
  8. #18
    Full Member ruksi's Avatar
    AutoCAD 2009
    Sep 2009
    40
    - Pick a point
    So See this
    Code:
    ;; local defun
    (or (vl-load-com))
    (setq
    "Acad_Tablestyle"
    name
    "AcDbTableStyle"
    ;; local defun
    table_data
    / acmcol
    acsp adoc
    axss cnt
    col columns
    dht lst_count
    objtable row
    rows
    (or (vl-load-com))
    (or adoc
    (vla-get-paperspace
    adoc)
    (vla-get-modelspace
    adoc))
    acsp
    'Addtable
    ins_point
    (+ 2 rows)
    columns
    (* dht 1.667);28
    (* dht 8.333);50
    (setq col 0
    row 1
    (setq col (1+ col))
    (setq row 2 col 0)
    (setq cnt 1 row 2)
    (setq col 0)
    (foreach a i
    (if (= col 0)
    (setq row (1+ row))
    (vl-catch-all-apply
    (function
    (lambda ()
    (vla-clear axss)
    (vla-delete axss)
    (alert "Done")
    ;; local defun
    (or (vl-load-com))
    (or adoc
    (vla-get-paperspace
    adoc)
    (vla-get-modelspace
    adoc))
    (car x)
    txt_height)))
    data_list
    ;; main part
    (initget "Y N")
    (if (eq "Y" ans)
    (setq num (1+ num))
    (while
    (setq num (1+ num))
    (initget "E A")
    (if (eq "E" ans)
    (foreach i pts
    fd)
    (close fd)
    Please I want to use this lisp file,But I can't find the command for active in cad
  9. #19
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,606
    Quote Originally Posted by ruksi View Post
    I am guessing PNT.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
  10. #20
    Super Member asos2000's Avatar
    asos2000's Computer Details
    WinXP
    AutoCAD 2007
    Sep 2007
    Cairo Egypt
    575
    to find the command
    find (defun C:
    the next word is the command
    So
    (defun C:PNT
    So PNT is command
    PS: its general for lisp.
    Sorry for my English.
  1. a lisp to apply 3 different lisp to 3 obj types filtered from one selection
    By gilsoto13 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Nov 2009, 05:28 am
  2. LISP calling another LISP
    By Rooster in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Aug 2009, 01:31 pm
  3. Lisp Call Lisp Problem
    By neekcotrack in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Aug 2008, 12:56 pm
  4. problem, trying to running a list of lisp from within a lisp
    By twind2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Aug 2007, 04:27 pm
  5. i want a lisp for cordinate
    By harshad in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Aug 2007, 09:48 am
