Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Forum Newbie
    AutoCAD 2010
    Apr 2010
    4
    Default "Un-union"ing a union
    Sorry guys, newbie question. I added several regions together using the "union" command. My question is, how do I remove a region after I have unioned it?
    Thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    How about Explode?
    Forum Newbie
    AutoCAD 2010
    Apr 2010
    4
    Ah, sorry if I was unclear about what I wanted.
    I drew a basic floor plan and used the Boundary/Region/Extrude commands. After I extruded the walls, I unioned them all together to get rid of the seams at the various wall points.
    Whenever I try to add a texture to a section of wall (living room for example), the entire wall section of the house changes to the same texture.
    I'm trying to figure out how to not physically delete objects from a union, but to remove them from the grouping property of the union command.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    I can't believe ReMark suggested Explode to someone who doesn't know 3D inside and out (and if you did, you wouldn't use Explode).
    You can use Imprint to separate faces for textures. Simply draw a rectangle (or other shape) on the face you want to split and then use the solidedit imprint command. (If the face isn't planar there is an extra step required of extruding first.)
    Post a simple example if you can't figure it out.
  5. #5
    Forum Newbie
    AutoCAD 2010
    Apr 2010
    4
    I tried using the solidedit command but could not figure it out. I'll try and post the example pictures that I have.
    The first pic is the general floor plan.
    The second one is the obvious selection whenever I select any part of the wall.
  6. #6
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    I am not familiar with editing pictures in AutoCAD - I meant post a dwg file (pared down if needed to file size limit).
    In your pretty picture I do not see anything to imprint to split the faces. You might want to check Help on Imprint or go through the tutorials in my signature.
    Actually looking at your picture again, unless you want to apply multiple textures to one face you should not need to use imprint to split the faces. You should be able to use the painter to apply to individual faces rather than the entire solid.
  7. #7
    Forum Newbie
    AutoCAD 2010
    Apr 2010
    4
    JD: Thanks for the input. However, since I am a novice at the program, I cannot seem to find the "painter" tool in the program. Would it be hidden under the Render or Draw tab in the ribbon somewhere?
  8. #8
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by crissmant View Post
    I am using the incorrect terminology - I seldom use AutoCAD anymore. Someone else will come along and set you in the right direction.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I suggested Explode because at first I thought the OP was working with simple 2D regions.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    From your AutoCAD Help file:
    Imprint
    "Imprints 2D geometry on a 3D solid or surface, creating additional edges on planar faces."
  1. "save" in the file "pull down menu" not working
    By kfarrar in forum Civil 3D & LDD
    Last Post: 25th Dec 2013, 10:22 am
  2. Move a "union"-object to exact coordinates
    By julaftonsful in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Jan 2010, 02:36 pm
  3. Replies: 1
    Last Post: 25th Nov 2009, 06:35 pm
  4. "LINK template" icons "greyed out" -why?
    By Chrisjpritchard in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 10:25 pm
  5. "Union" Meshes or "Slice" 3D Mesh
    By Peter31712 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2004, 11:11 pm
