Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    JDM: Were you perhaps referring to the Color Faces command?
  2. #12
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Command: IMPRINT
    Select a 3D solid or surface: Select your solid; that would be your wall.
    Select an object to imprint: This would be a retangle, for example, that you have drawn on your wall.
    Delete the source object [Yes/No] <N>: The default is "No". Not sure why. Maybe AutoCAD expects the user to repeat the command using the same object elsewhere.
    At this point AutoCAD will "imprint" (think of it as "stamping") your wall with the shape of the rectangle.
    Select an object to imprint: AutoCAD continues to repeat the command. Press Esc to cancel.
    Now you can color a face or apply materials to two or more sections of one wall even if in your case that wall wraps the entire house inside and out.
  3. #13
    Senior Member
    AutoCAD 2014
    Nov 2007
    Berkshire
    104
    You Could select the solid and the hold down ctrl and alt and select the wall and then go to properties and change the material to the required one and this should only change on the surface that you have selected
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    This is what you'll get if the object you are imprinting is not on the solid wall (where AutoCAD expects it to be).
    Command: Imprint
    Modeling Operation Error:
    No intersection edges.
    The selected object must intersect the faces of the solid.
    Select an object to imprint: *Cancel*
  5. #15
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    No - I assumed the OP was looking for something more sophisticated by applying material textures. I just switched over to 2011 and couldn't get it to work as I remembered or get Help to give me any help.
  6. #16
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,728
    I suggested Explode because at first I thought the OP was working with simple 2D regions.
    I often get flack because I almost always request a file. My experience has taught me not to assume the OP is able to correctly describe the problem statement. It seems logical to me that since we are dealing with a geometric form of communication that it should be obvious to ALWAYS include a file.
    I can't figure out what the purpose is of learning a CAD program to communicate and then ignoring the obvious - use the CAD file to communicate.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    "I can't figure out what the purpose is of learning a CAD program to communicate and then ignoring the obvious - use the CAD file to communicate."
    A point that cannot be made strongly enough. I agree wholeheartedly.
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Re: Color faces. I was trying to make sense of the OP's reference to "painting" an object. I have no use for materials although I use the Color Faces command from time to time. It was the only thing I could think of.
    I need to get out and start experimenting with applying materials.
  9. #19
    Junior Member
    Architecture 2011
    Dec 2007
    U.S. New Jersey
    23
    I may be mistaken but I believe that if you hold down the control key when selecting a surface for material application, it will only do that surface. ie. As in only one face of a wall. See if that works
  10. #20
    Junior Member
    primalscr33m's Computer Details
    Visat Ultimate 64 bit
    Custom Built
    Gigabyte EP45-DSP4
    Core 2 Quad Q9550 @ 3.7 GHz
    8 Gb of DDR2 1066
    Gigabyte Radeon 4870 X2
    WD 600 Gb
    WD 1000 Gb
    Dell Ultrasharp U2711 27 Inch 2560 x 1440
    AutoCAD 2010
    May 2010
    Sydney, Australia
    11
    Im not sure if this seems too simplistic, but I would just copy the face of the wall I wanted and extrude the resulting face .1 mm, creating a new solid and apply the texture to that.
    The original solid would be the skeleton, and all resulting faces copied and extruded would have the material properties I was after applied to them.
    If I wanted two or three different textures per face I would just divide up the new face as required.
    Is this too primitive a method?
  1. "save" in the file "pull down menu" not working
    By kfarrar in forum Civil 3D & LDD
    Last Post: 25th Dec 2013, 10:22 am
  2. Move a "union"-object to exact coordinates
    By julaftonsful in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Jan 2010, 02:36 pm
  3. Replies: 1
    Last Post: 25th Nov 2009, 06:35 pm
  4. "LINK template" icons "greyed out" -why?
    By Chrisjpritchard in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 10:25 pm
  5. "Union" Meshes or "Slice" 3D Mesh
    By Peter31712 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Apr 2004, 11:11 pm
