Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 58
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    Default Need Help with 3 things...
    All I know how to do in 3d is make a 2d profile of an object and extrude it like this
    Now I need to know how to make more complex shapes.
    1. How should I go about making this shape?
    2. I also need to know how to make a hole in the objects like this....
    3. How do I make the concrete looking texture on all sides?
    Thanks.
    Senior Member
    AutoCAD 2014
    Nov 2007
    Berkshire
    104
    1) draw a polyline as you want the hand rail to go and then when you extrude the profile (use path and select the polyline)
    2) if the hole goes all the way along the hand rail then draw the circle and extrude along the path and subtract frame the rail
    if it only goes in so fare at the end of the rail then draw the cicle on the end surface and use the push pull command
    3) not great with the materials perhaps some one else can help
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    Thanks, do you know of a tutorial that uses polylines and paths to extrude profiles on? If not, I'm sorry but thats a bit over my head. If you could give me a few steps to take to make it I would really appreciate it.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    In addition to Extrude there is also Press/Pull and Sweep not to mention the use of Polysolid.
    A path can be something as simple as a line.
    A circle...well that needs no explanation.
    Knowing how to reorient the UCS is of prime importance when working in 3D.
    If you draw the circle at the end of the line, in the proper orientation to the line, then invoke the Extrude command simply follow the prompts after that.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Example of Extrude command using Path option.
    Circle (red) and our path (line in black) on left. Result in red on right.
  6. #6
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by Mason Dixon View Post
    Thanks, do you know of a tutorial that uses polylines and paths to ....
    http://home.pct.edu/~jmather/content...torial%208.pdf
  7. #7
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    Thanks, just what I needed.
  8. #8
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    How can I make this shape with the hipped end.
    Also, has anyone got any ideas on how I can make the sides look like concrete?
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    What is a "hipped" end?
    The object can be made to look like concrete by applying a material to it, setting up your light source then rendering it.
  10. #10
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    The hipped part is where it angles down on the left side. How is that created?
  1. One of these things is not like the other
    By sward in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Feb 2008, 02:45 pm
  2. help on two things
    By Bobby in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Dec 2006, 06:24 pm
  3. A few things...
    By focus1 in forum AutoCAD Beginners' Area
    Last Post: 24th May 2006, 09:18 pm
  4. 2 things...can anyone help
    By doboy in forum AutoCAD General
    Last Post: 15th Nov 2003, 11:40 pm
