Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 58 of 58
  1. #51
    Senior Member
    AutoCAD 2010
    Jun 2009
    206
    How do I get the get the green/red/blue arrows and the 3dcube(upper right) to show in autocad?
  2. #52
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,598
    The "arrows" are your UCS icon. UCSicon > On.
    Navvcube > On for the other.
  3. #53
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    ...and shademode in one of the 3d options.
  4. #54
    Super Member MikeScott's Avatar
    MikeScott's Computer Details
    XP Pro
    Dell Precision T3400
    2.67 gigahertz Intel Core2 Duo
    2046 Mb
    NVIDIA Quadro NVS 290/ 256MB DDR2
    ST3500418AS/ 500gb (450gb free)
    DELL G2410 (24.0"vis)
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    I didn't see you were letting me off the hook on this.. so I did pics this morning before work.
    Maybe it's not usefull to someone with a fully preplanned handrail (or piece of molding), but if you're ever stuck with a deadend, it'll get you through it. I'm still having trouble preplanning the ends while extruding, so I'd still rely on this to finish-up the ends, personally.
    Sorry about the picture sizes.. I didn't have time to make it nice. Guess I should've put borders on the pics too.. to make it easier to read where each picture begins and ends.
    The first pic is simply the starting point picture, and the last picture shows it unioned. The commands used are visible in the command window. I hope it makes sense... I thought that the way the images were posted, it'd permit me to add comments between each one, but apparently not.
    *Edit*
    The first arrow is pointing at the endpoint used as a starting position for the line. (forgot to note it)
    UCS is set to World, and the View is set at Isometric SW..
  5. #55
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,598
    You put yourself on the hook...you get yourself off.
    I don't know why you would have a problem with pre-planning the ends. I'd create a library of typical end pieces (with returns) that I could just attach to a straight run. Call it run and done.
  6. #56
    XP Pro
    2046 Mb
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    I use custom molding profiles as provided by architects as a large part of what I do, but even if I could simply use premade molding endings, there are an awful lot of existing options out there for them to select from.
    Most architects have a tendency to use a regular stick of molding and want us to combine it to a new profile and tell us that a seam is not permitted. The molding is typically selected from a catalog that's local to them, or sometimes we even get the direction to match a profile they have on-site that was installed like 50 years ago with no idea of it's origin.
    So on these "handrail backers" I have to make my own ends. I think my steps at least indicate that it's not a very involved process.. but the earlier mention was to how easy it'd be to do that, and I wondered if there was an even quicker way I'd been overlooking.
  7. #57
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,598
    Quicker way? Since you would have to create the profile anyway why couldn't you just sweep it along a guide and make like an end cap? Use Move Faces to shorten the end of the handrail backer add the newly created end piece and union everything together.
  8. #58
    XP Pro
    2046 Mb
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    Because I can't sweep on this version (2004). However, even if I could, unless I cut the profile in half and somehow got it to make a 180 degree turn with a squared edge and come back, it won't create the endcap if the profile has a peaked top.
    Kencaz's example only works because the center of the molding is flat in his example (and mine). Ken followed the block with his guide, but if that were a peak, they'd have to create it seperately with presspull or something, and THEN apply the partial profile thing. That's because you can't sweep in a straight line with one point pivoting, like the topmost point would have to do.
    If it were peaked, like the Submitter's version, my method would still work, but the kencaz method would require you make that peaked portion seperately.
    Now.. the Sweep would be great for turning corners and doing the overall primary handrail, but I don't see how you'd get the double-Miter required to begin/end the piece solely using sweep on even multiple partial profiles.
    It's all good though, if there isn't a way, mine will continue to work for me.
    Actually, I just figured-out a way to speed that up.. mirror the handrail, rotate it 90-degrees, and use the interfere command. BLAM! that would make a 4-way endcap that can be unioned-on wherever you need it.
    Sure beats going back to sweeping partial profiles and/or making slices, and yet would still work with a peaked top. Thanks for the exercise.
  1. One of these things is not like the other
    By sward in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Feb 2008, 02:45 pm
  2. help on two things
    By Bobby in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Dec 2006, 06:24 pm
  3. A few things...
    By focus1 in forum AutoCAD Beginners' Area
    Last Post: 24th May 2006, 09:18 pm
  4. 2 things...can anyone help
    By doboy in forum AutoCAD General
    Last Post: 15th Nov 2003, 11:40 pm
