Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 37
    Senior Member Efeezy's Avatar
    MEP 2012
    Jan 2010
    Seattle WA
    123
    Default Replace Selected Block Or Blocks With Another Block
    DOES ANYONE HAVE A QUICK AND EASY WAY TO REPLACE A SELECTED BLOCK. ALSO IS THERE A WAY TO REPLACE MULTIPLE SLECTED BLOCKS AND REPLACE WITH A DIFFERENT BLOCK TYPICAL FOR ALL THE BLOCKS THAT ARE SELECTED? I HAVE A BIG A$$ PROJECT DUE FRIDAY AND NEED TO SWAP OUT ALOT OF BLOCKS NOW...
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Ouch... not so loud
    Have you tried the Express Tools' Blockreplace?
    MEP 2012
    Jan 2010
    Seattle WA
    123
    LOL sorry about that. Yes, I have express tools. The Blockreplace command replaces all the blocks i just want to replace the block that I have manually selected. I pulled an old stript and trying to alter it but not sure if I can pull it off though.
    MEP 2012
    Jan 2010
    Seattle WA
    123
    nope couldn't get the script to work I am a not good at writing or modifying lisp my bock i need to replace is smoke 1 with smoke rb
    Code:
    (defun c:rblk (/ pre nb ss i en ed)(while (or (not pre)(not (snvalid pre)))(setq pre (getstring "\nExisting BLOCKs Name Prefix:   ")))(while (not nb)(setq nb (getstring "\nNew BLOCK Name:   "))(cond ((not (snvalid nb))(setq nb nil))((tblsearch "BLOCK" nb))((findfile (strcat nb ".DWG"))(command "_.INSERT" nb)(command))(T (setq nb nil))))(and (setq ss (ssget "X" (list (cons 0 "INSERT")(cons 2 (strcat pre "*")))))(setq i (sslength ss))(while (not (minusp (setq i (1- i))))(setq en (ssname ss i)                    ed (entget en))(entmod (subst (cons 2 nb) (assoc 2 ed) ed))(entupd en)))(prin1))
  5. #5
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    I've had this in my archives for a long time, hope it works for you
  6. #6
    Full Member manirpg's Avatar
    manirpg's Computer Details
    Windows Vista
    DELL
    2GB
    TFT
    Revit MEP 2012
    May 2010
    Mumbai,INDIA.
    50
    Default good one
    Good one.........its working fine...Mr.Efeezy, Are u got solution? if yes complete the target before due..................Congrats...
  7. #7
    Senior Member
    AutoCAD 2009
    Jul 2009
    267
    Quote Originally Posted by Efeezy View Post
    try Bre.lsp from Alan Thompson... It's works quite well..
    See updated CODE
  8. #8
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by gilsoto13 View Post
    I forgot all about that one. Haven't used it since the project I wrote it for.
    Original link
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  9. #9
    Super Member qball's Avatar
    Structural
    qball's Discipline Details
    Structural
    Structural / Architectural, Residential, Multi-family, Industrial, Wood frame, Steel, Masonry, Concrete, Tilt-up
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    bre is good!
  10. #10
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by qball View Post
    bre is good!
    Glad you like it. I wish I could remove that old version gilsoto posted, but here's an updated version:
    Code:
    (defun c:BRE (/ *error* blk f ss temp)
      ;; Replace multiple instances of selected blocks (can be different) with selected block
      ;; Size and Rotation will be taken from original block and original will be deleted
      ;; Required subroutines: AT:GetSel
      ;; Alan J. Thompson, 02.09.10
      (vl-load-com)
      (defun *error* (msg)
        (and f *AcadDoc* (vla-endundomark *AcadDoc*))
        (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
      (if
        (and
          (AT:GetSel
            entsel
            "\nSelect replacement block: "
            (lambda (x / e)
              (if
                (and
                  (eq "INSERT" (cdr (assoc 0 (setq e (entget (car x))))))
                  (/= 4 (logand (cdr (assoc 70 (tblsearch "BLOCK" (cdr (assoc 2 e))))) 4))
                  (/= 4 (logand (cdr (assoc 70 (entget (tblobjname "LAYER" (cdr (assoc 8 e)))))) 4))
                 (setq blk (vlax-ename->vla-object (car x)))
          (princ "\nSelect blocks to be repalced: ")
          (setq ss (ssget "_:L" '((0 . "INSERT"))))
           (setq f (not (vla-startundomark
                          (cond (*AcadDoc*)
                                ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
           (vlax-for x (setq ss (vla-get-activeselectionset *AcadDoc*))
             (setq temp (vla-copy blk))
             (mapcar (function (lambda (p)
                                 (vl-catch-all-apply
                                   (function vlax-put-property)
                                   (list temp p (vlax-get-property x p))
                     '(Insertionpoint Rotation XEffectiveScaleFactor YEffectiveScaleFactor
                       ZEffectiveScaleFactor
             (vla-delete x)
           (vla-delete ss)
           (*error* nil)
    (defun AT:GetSel (meth msg fnc / ent good)
      ;; meth - selection method (entsel, nentsel, nentselp)
      ;; msg - message to display (nil for default)
      ;; fnc - optional function to apply to selected object
      ;; Ex: (AT:GetSel entsel "\nSelect arc: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "ARC")))
      ;; Alan J. Thompson, 05.25.10
      (setvar 'errno 0)
      (while (not good)
        (setq ent (meth (cond (msg)
                              ("\nSelect object: ")
        (cond
          ((vl-consp ent)
           (setq good (cond ((or (not fnc) (fnc ent)) ent)
                            ((prompt "\nInvalid object!"))
          ((eq (type ent) 'STR) (setq good ent))
          ((setq good (eq 52 (getvar 'errno))) nil)
          ((eq 7 (getvar 'errno)) (setq good (prompt "\nMissed, try again.")))
    DropBox
  1. block replace and dynamic blocks
    By Glen Smith in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jul 2014, 07:27 pm
  2. How to Copy as a block (with all selected external referance and blocks)
    By samcoozy in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th May 2010, 10:55 am
  3. Replies: 3
    Last Post: 19th Mar 2010, 04:47 pm
  4. Replace Multiple blocks with one block
    By cbriana in forum AutoCAD General
    Last Post: 20th Jan 2010, 03:29 pm
  5. A Lisp to redefine selected blocks with current block scale as 1,1,1?
    By gilsoto13 in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Sep 2009, 07:37 am
