Replace Selected Block Or Blocks With Another Block
Efeezy
DOES ANYONE HAVE A QUICK AND EASY WAY TO REPLACE A SELECTED BLOCK. ALSO IS THERE A WAY TO REPLACE MULTIPLE SLECTED BLOCKS AND REPLACE WITH A DIFFERENT BLOCK TYPICAL FOR ALL THE BLOCKS THAT ARE SELECTED? I HAVE A BIG A$$ PROJECT DUE FRIDAY AND NEED TO SWAP OUT ALOT OF BLOCKS NOW...:cry:
  • Replies 37
  • alanjt
    9
  • Efeezy
    3
  • lpseifert
    2
  • justindm
    2
LOL sorry about that. Yes, I have express tools. The Blockreplace command replaces all the blocks i just want to replace the block that I have manually selected. I pulled an old stript and trying to alter it but not sure if I can pull it off though.
nope couldn't get the script to work I am a not good at writing or modifying lisp my bock i need to replace is smoke 1 with smoke rb
[b]([/b]defun c:rblk [b][color=fuchsia]([/color][/b]/ pre nb ss i en ed[b][color=fuchsia])[/color][/b][b][color=fuchsia]([/color][/b]while [b][color=navy]([/color][/b]or [b][color=maroon]([/color][/b]not pre[b][color=maroon])[/color][/b][b][color=maroon]([/color][/b]not [b][color=green]([/color][/b]snvalid pre[b][color=green])[/color][color=maroon])[/color][color=navy])[/color][/b][b][color=navy]([/color][/b]setq pre [b][color=maroon]([/color][/b]getstring [color=darkslategray]"\nExisting BLOCKs Name Prefix:   "[/color][b][color=maroon])[/color][color=navy])[/color][color=fuchsia])[/color][/b][b][color=fuchsia]([/color][/b]while [b][color=navy]([/color][/b]not nb[b][color=navy])[/color][/b][b][color=navy]([/color][/b]setq nb [b][color=maroon]([/color][/b]getstring [color=darkslategray]"\nNew BLOCK Name:   "[/color][b][color=maroon])[/color][color=navy])[/color][/b][b][color=navy]([/color][/b]cond [b][color=maroon]([/color][color=green]([/color][/b]not [b][color=blue]([/color][/b]snvalid nb[b][color=blue])[/color][color=green])[/color][/b][b][color=green]([/color][/b]setq nb nil[b][color=green])[/color][color=maroon])[/color][/b][b][color=maroon]([/color][color=green]([/color][/b]tblsearch [color=darkslategray]"BLOCK"[/color] nb[b][color=green])[/color][color=maroon])[/color][/b][b][color=maroon]([/color][color=green]([/color][/b]findfile [b][color=blue]([/color][/b]strcat nb [color=darkslategray]".DWG"[/color][b][color=blue])[/color][color=green])[/color][/b][b][color=green]([/color][/b]command [color=darkslategray]"_.INSERT"[/color] nb[b][color=green])[/color][/b][b][color=green]([/color][/b]command[b][color=green])[/color][color=maroon])[/color][/b][b][color=maroon]([/color][/b]T [b][color=green]([/color][/b]setq nb nil[b][color=green])[/color][color=maroon])[/color][color=navy])[/color][color=fuchsia])[/color][/b][b][color=fuchsia]([/color][/b]and [b][color=navy]([/color][/b]setq ss [b][color=maroon]([/color][/b]ssget [color=darkslategray]"X"[/color] [b][color=green]([/color][/b]list [b][color=blue]([/color][/b]cons 0 [color=darkslategray]"INSERT"[/color][b][color=blue])[/color][/b][b][color=blue]([/color][/b]cons 2 [b][color=red]([/color][/b]strcat pre [color=darkslategray]"*"[/color][b][color=red])[/color][color=blue])[/color][color=green])[/color][color=maroon])[/color][color=navy])[/color][/b][b][color=navy]([/color][/b]setq i [b][color=maroon]([/color][/b]sslength ss[b][color=maroon])[/color][color=navy])[/color][/b][b][color=navy]([/color][/b]while [b][color=maroon]([/color][/b]not [b][color=green]([/color][/b]minusp [b][color=blue]([/color][/b]setq i [b][color=red]([/color][/b]1- i[b][color=red])[/color][color=blue])[/color][color=green])[/color][color=maroon])[/color][/b][b][color=maroon]([/color][/b]setq en [b][color=green]([/color][/b]ssname ss i[b][color=green])[/color][/b]                    ed [b][color=green]([/color][/b]entget en[b][color=green])[/color][color=maroon])[/color][/b][b][color=maroon]([/color][/b]entmod [b][color=green]([/color][/b]subst [b][color=blue]([/color][/b]cons 2 nb[b][color=blue])[/color][/b] [b][color=blue]([/color][/b]assoc 2 ed[b][color=blue])[/color][/b] ed[b][color=green])[/color][color=maroon])[/color][/b][b][color=maroon]([/color][/b]entupd en[b][color=maroon])[/color][color=navy])[/color][color=fuchsia])[/color][/b][b][color=fuchsia]([/color][/b]prin1[b][color=fuchsia])[/color][color=black])[/color][/b]
Edited by SLW210
:D:DGood one.........its working fine...Mr.Efeezy, Are u got solution? if yes complete the target before due..................Congrats...:D:D
try Bre.lsp from Alan Thompson... It's works quite well..
See updated CODE
Edited by SLW210
Removed Lisp File
  • 4 months later...
bre is good! :D
Glad you like it. I wish I could remove that old version gilsoto posted, but here's an updated version:
(defun c:BRE (/ *error* blk f ss temp)
 ;; Replace multiple instances of selected blocks (can be different) with selected block
 ;; Size and Rotation will be taken from original block and original will be deleted
 ;; Required subroutines: AT:GetSel
 ;; Alan J. Thompson, 02.09.10
 (vl-load-com)
 (defun *error* (msg)
   (and f *AcadDoc* (vla-endundomark *AcadDoc*))
   (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
 (if
   (and
     (AT:GetSel
       entsel
       "\nSelect replacement block: "
       (lambda (x / e)
         (if
           (and
             (eq "INSERT" (cdr (assoc 0 (setq e (entget (car x))))))
             (/= 4 (logand (cdr (assoc 70 (tblsearch "BLOCK" (cdr (assoc 2 e))))) 4))
             (/= 4 (logand (cdr (assoc 70 (entget (tblobjname "LAYER" (cdr (assoc 8 e)))))) 4))
            (setq blk (vlax-ename->vla-object (car x)))
     (princ "\nSelect blocks to be repalced: ")
     (setq ss (ssget "_:L" '((0 . "INSERT"))))
      (setq f (not (vla-startundomark
                     (cond (*AcadDoc*)
                           ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
      (vlax-for x (setq ss (vla-get-activeselectionset *AcadDoc*))
        (setq temp (vla-copy blk))
        (mapcar (function (lambda (p)
                            (vl-catch-all-apply
                              (function vlax-put-property)
                              (list temp p (vlax-get-property x p))
                '(Insertionpoint Rotation XEffectiveScaleFactor YEffectiveScaleFactor
                  ZEffectiveScaleFactor
        (vla-delete x)
      (vla-delete ss)
      (*error* nil)
(defun AT:GetSel (meth msg fnc / ent good)
 ;; meth - selection method (entsel, nentsel, nentselp)
 ;; msg - message to display (nil for default)
 ;; fnc - optional function to apply to selected object
 ;; Ex: (AT:GetSel entsel "\nSelect arc: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "ARC")))
 ;; Alan J. Thompson, 05.25.10
 (setvar 'errno 0)
 (while (not good)
   (setq ent (meth (cond (msg)
                         ("\nSelect object: ")
   (cond
     ((vl-consp ent)
      (setq good (cond ((or (not fnc) (fnc ent)) ent)
                       ((prompt "\nInvalid object!"))
     ((eq (type ent) 'STR) (setq good ent))
     ((setq good (eq 52 (getvar 'errno))) nil)
     ((eq 7 (getvar 'errno)) (setq good (prompt "\nMissed, try again.")))
Edited by alanjt
  • 1 month later...
I'm trying to run the above but get an error: "Error: no function definition: VLAX-ENAME->VLA-OBJECT"
Some of the blocks I'm selecting have spaces, dashes and underscores...could that be a problem?
  • 1 year later...
  • 7 months later...
 (vl-load-com)
 (if
   (and
     (AT:GetSel
       entsel
       (lambda (x / e)
         (if
           (and
                     (cond (*AcadDoc*)
                            (vl-catch-all-apply
        (vla-delete x)
      (vla-delete ss)
      (*error* nil)
 (setvar 'errno 0)
 (while (not good)
   (cond
     ((vl-consp ent)
Hi Alan J,
I've been searching for a block replace Lisp for three days but couldn't find any good one. I found this lisp it is working nice, I wanted to ask is it possible to make this lisp a batch block replacement so that you don't need to open every drawing to change blocks. I have to replace old blocks from new blocks in more than 300 drawings.
If it is possible plz tell.
Thanks for your previous (BRE) Lisp too.
  • 10 months later...
Do you have a similar routine that wors with attributes? I often have to change (blocks with attributes) parts of my drawing from proposed to existing. The blocks are the same except for color and font style. Thanks
