+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Full Member
    Using
    AutoCAD 2011
    Join Date
    May 2010
    Posts
    63
    Default Mapping materials: grass, concrete etc.
    Hi guys, I was hoping for some tips on creating grass. I find it very hard to create a material map which dosnt look like crap. Currently I am just using a diffuse bitmap and trying to scale it accordingly (which is not working obviously) my skills in max are limited somewhat so i was hoping on maybe some easy tips and tricks in creating a large grass scene, or point me in the right tutorial direction.
    The model was imported from a civil point file and is also quite angular which dosn't help the realism of it all, so if there is any directional advice on that part also would be appreciated.
    Kind Regards.
    ps, As you can see in the images below there are quite pixilated lines where the 3d faces meet on the civil surface, how do I get rid of them? my render settings are quite high so I dont even know why they are pixeled.
    Thanks again in advance
  2. #2
    Super Moderator Cad64's Avatar
    Computer Details
    Cad64's Computer Details
    Operating System:
    Windows 7 Profesional x64
    Computer:
    XI Computers
    Motherboard:
    Asus P8Z77-V Pro
    CPU:
    Intel Core I7 3770K 4.1 Ghz Quad Core 3rd Gen
    RAM:
    8GB DDR3 @ 1333MHz
    Graphics:
    Nvidia GeForce GTX 570 1280MB GDDR5
    Primary Storage:
    SATAII 500GB 7200 RPM
    Secondary Storage:
    Western Digital My Book Studio Edition II - 2TB capacity
    Monitor:
    HPf2105 21" LCD Widescreen & Cintiq 21ux
    Discipline
    Multi-disciplinary
    Cad64's Discipline Details
    Occupation
    Freelance Digital Artist
    Discipline
    Multi-disciplinary
    Details
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    Using
    3ds Max 2011
    Join Date
    Feb 2006
    Location
    Southern California
    Posts
    8,433
    Default
    This is sort of an advanced project and there are many things that you will need to do in order to get the result you require.
    Civil files are always very rough, so you need to do a lot of preliminary work to clean them up before importing them into Max. You will also need to separate the hardscape objects from the landscape, and put everything on different layers, so you can work on them independantly in Max.
    Once your CAD file is cleaned and imported you can smooth out the terrain with a Meshsmooth modifier to get rid of those creases and pinch points.
    In order to apply materials correctly, you will need to UVW map your objects. You can learn about UVW mapping here: http://waylon-art.com/uvw_tutorial/uvwtut_01.html
    Once your UV's are established, then you can apply your materials.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  3. #3
    Full Member
    Using
    AutoCAD 2011
    Join Date
    May 2010
    Posts
    63
    Default thanks
    thanks mate, yeh the file was a bit of a monster. so many 3d faces, i think the point file by itself was close to 80mb. Anyway appreciate the advice.
  4. #4
    Super Member
    Using
    AutoCAD 2008
    Join Date
    Jul 2007
    Posts
    536
    Default
    You could have used the retopology (Graphite modeling) tools to create a tidier surface in Max prior to texturing. They're quite simple to use if you take a little time to learn them. Or you can edit your surface and delete points in C3D if they're looking a little untidy. The former is probably quicker and easier.
    Using AutoCAD2012, Civil 3D 2012, 3DS Max 2012, AutoCAD MEP 2011, Imagemodeler 2009, Zbrush, Solidworks, PTGui, Photomatix, Photoshop
    PORTFOLIO: http://www.flickr.com/photos/47676682@N04/
  5. #5
    Junior Member
    Computer Details
    cec_casbie_novice's Computer Details
    Operating System:
    Windows Vista
    Computer:
    PC, with logitec trackball mouse and two screens
    Using
    Map 3D 2010
    Join Date
    Jul 2010
    Location
    UK
    Posts
    10
    Default
    I would re-draw in photoshop, as long as there weren't too many stills to do!
    Cas
  6. #6
    Computer Details
    Operating System:
    Computer:
    XI Computers
    Motherboard:
    Asus P8Z77-V Pro
    CPU:
    RAM:
    8GB DDR3 @ 1333MHz
    Graphics:
    Primary Storage:
    Secondary Storage:
    Monitor:
    Discipline
    Multi-disciplinary
    Occupation
    Discipline
    Multi-disciplinary
    Details
    Using
    3ds Max 2011
    Join Date
    Feb 2006
    Location
    Southern California
    Posts
    8,433
    Default
    Kind of defeats the whole purpose of doing the 3D model doesn't it?
  7. #7
    Junior Member
    Computer Details
    Operating System:
    Windows Vista
    Computer:
    Using
    Map 3D 2010
    Join Date
    Jul 2010
    Location
    UK
    Posts
    10
    Default
    ahh, was just going to say 'work smarter, not harder' then saw your strapline!
Similar Threads
  1. 3DS Grass
    By nocturne00 in forum 3D Modelling
    Last Post: 12th Jul 2009, 07:12 am
  2. Realistic Grass Anyone????
    By watso75 in forum 3D Modelling
    Last Post: 16th May 2009, 05:28 pm
  3. Mapping materials
    By gbotham in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Apr 2009, 09:10 pm
  4. My tips(Unterstanding between planner mapping & box mapping)
    By papagyi in forum Tutorials & Tips'n'Tricks
    Last Post: 2nd Nov 2008, 01:30 pm
  5. uvw mapping and unwwap uvw mapping
    By al_farooq in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Mar 2007, 10:03 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
