gsksun4 Posted May 28, 2010 Share Posted May 28, 2010 I'm almost afraid to ask this. How do you do dtext in isometric? I have attached a small test drawing and I want to put text on the large area on the same 30 degree angle. This is just a test file. Thanks. Glenn 2009LT ISO-TEXT.dwg Quote Link to comment Share on other sites More sharing options...
lpseifert Posted May 28, 2010 Share Posted May 28, 2010 Make 2 text styles with oblique angles of 30 and -30 degrees. When creating the text use increments of 30 degrees for the angle. ACAD-ISO-TEXT.dwg Quote Link to comment Share on other sites More sharing options...
gsksun4 Posted May 28, 2010 Author Share Posted May 28, 2010 Make 2 text styles with oblique angles of 30 and -30 degrees. When creating the text use increments of 30 degrees for the angle. That's pretty simple and already in my notes. Thank you. Quote Link to comment Share on other sites More sharing options...
Tankman Posted May 28, 2010 Share Posted May 28, 2010 You might brush up a bit at this website. Take a peek-a-boo at chapter 40. You can print off the lesson or save to your HDD; *.pdf file format. http://www.andrew.cmu.edu/course/48-568/2DVideosWEB_files/frame.htm ISO-TEXT-2.dwg Quote Link to comment Share on other sites More sharing options...
gsksun4 Posted May 28, 2010 Author Share Posted May 28, 2010 You might brush up a bit at this website. Take a peek-a-boo at chapter 40.You can print off the lesson or save to your HDD; *.pdf file format. http://www.andrew.cmu.edu/course/48-568/2DVideosWEB_files/frame.htm Tankman. These tutorials are great, Heh, she even used my regular font ROMANS. I wish I had this tutorial 20 years ago. I put this in my favorites a week ago. Thank you Sir. Quote Link to comment Share on other sites More sharing options...
Tankman Posted May 28, 2010 Share Posted May 28, 2010 Tankman. These tutorials are great, Heh, she even used my regular font ROMANS. I wish I had this tutorial 20 years ago. I put this in my favorites a week ago. Thank you Sir. Excellent, I too could've used them years ago. Take a peek-a-boo at my drawing posted, and take a look at your drawing. Might be wrong but, was your ISO at 24°? Where are you posting from? Just curious. Quote Link to comment Share on other sites More sharing options...
gsksun4 Posted May 28, 2010 Author Share Posted May 28, 2010 Excellent, I too could've used them years ago. Take a peek-a-boo at my drawing posted, and take a look at your drawing. Might be wrong but, was your ISO at 24°? Where are you posting from? Just curious. Yeah, I noticed that when I put the isotext in. Haste makes waste as they say. I'm in St. Pete, Florida. By the way, I'm now testing this in MTEXT, but not getting the same results. I set the rotation in the command line at 30 degrees and in the MTEXT window I set the oblique at 30 degrees, but it's not right. I'm using 2009LT. Quote Link to comment Share on other sites More sharing options...
Tankman Posted May 29, 2010 Share Posted May 29, 2010 I don't see oblique as a property for MTEXT. MTEXT setting oblique? Don't see that when I start to type. I do see the angle setting. Was able to enter text at 30° then adjust oblique to 30° in "modify properties." Didn't look right, edited text adding a blank space at the beginning of "CadTutor Forums." Quote Link to comment Share on other sites More sharing options...
gsksun4 Posted June 1, 2010 Author Share Posted June 1, 2010 I don't see oblique as a property for MTEXT. MTEXT setting oblique? Don't see that when I start to type. I do see the angle setting. Was able to enter text at 30° then adjust oblique to 30° in "modify properties." Didn't look right, edited text adding a blank space at the beginning of "CadTutor Forums." OK, now I got it. I set the oblique angle in the formatting mgr, then set the rotation angle in the properties mgr. Only thing is, it works for the 30 degree but not the -30. Oh well, no big deal. Thanks Tankman. Quote Link to comment Share on other sites More sharing options...
rkent Posted June 1, 2010 Share Posted June 1, 2010 If it won't accept -30 then use 330. Quote Link to comment Share on other sites More sharing options...
gsksun4 Posted June 2, 2010 Author Share Posted June 2, 2010 If it won't accept -30 then use 330. Tried that too. It comes out an odd angle. Also, if I don't set the style mgr to -30 oblique first, it completely kicks me out of cad in MTEXT when I hit OK. Acad LT Alert. AutoCad cannot continue. It's probably an LT glitch. But it doesn't make sense. I can do the text on a 30, but not a -30 or 330. DTEXT works fine with both, it's the MTEXT with the problem. Quote Link to comment Share on other sites More sharing options...
