+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Forum Newbie
    Using
    AutoCAD 2010
    Join Date
    May 2010
    Posts
    2
    Default Issues converting to a solid
    Already looked around for a solution to this problem, but have yet to figure it out. I'm newish to AutoCAD (dabbled off and on, but mostly in 2d) but a quick learner.
    Basically I'm designing a quarter spiral staircase, more specifically, the stringer to support them. This isn't the final model of the stringer I will be using, but to be able to convert this back into a solid will be helpful so I can subtract other parts of the staircase from it.
    The original solid was created using thicken from a 2d polyline converted into a region. I then subtracted a piece from it, exploded the 3d solid and reshaped the wireframe into what you see in my DWG.
    I cant seem to turn it back into a 3d solid. CONVTOSOLID gives me a "Cannot convert an open curve" error. I'm pretty sure that the model is closed, but like I said, newish to AutoCAD, and not sure exactly how to check.
    Ive been reading (and learning alot from) these forums for a while now, and this is the first issue that I wasn't able to find a solution for. Maybe I'm just not asking the search engine the right questions - and apologies if this is a repost in sheep's clothing.
  2. #2
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2015
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    8,731
    Default
    Quote Originally Posted by Atticus;330457... [B
    exploded[/B] the 3d solid and reshaped the wireframe into what you see in my DWG.
    Ive been reading (and learning alot from) these forums for a while now, ...
    You should have read to never never never explode a solid (or at least make a backup file first).
    Certified SolidWorks Professional
    Autodesk Inventor 2015 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
  3. #3
    Super Member kencaz's Avatar
    Computer Details
    kencaz's Computer Details
    Operating System:
    XP Pro, Vista, Linux,W7
    Computer:
    HP,s Dell
    Discipline
    Mechanical
    kencaz's Discipline Details
    Occupation
    Designer/Machinist
    Discipline
    Mechanical
    Using
    AutoCAD 2013
    Join Date
    Jul 2007
    Location
    Las Vegas, NV
    Posts
    759
    Default
    I used press-pull to extrude and again to cut the angles... Have you tried it yet...?
    KC
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
  4. #4
    Forum Newbie
    Using
    AutoCAD 2010
    Join Date
    May 2010
    Posts
    2
    Default
    Quote Originally Posted by JD Mather View Post
    why shouldn't I explode a 3D object? and up try the press pull when I get home, just starting my shift.
  5. #5
    Senior Member rvpas's Avatar
    Computer Details
    rvpas's Computer Details
    Operating System:
    Seven Pro
    Computer:
    laptop HP EliteBook 8760w - workstation hp
    Discipline
    Architectural
    rvpas's Discipline Details
    Occupation
    building CAD designer and AUTOCAD ATC instructor free lance
    Discipline
    Architectural
    Details
    Help to design building with architect work with REVIT and AUTOCAD during the step of conception, follow the contruction site, building survey. ATC Instructor with trainng center 2d 3d AUTOCAD and REVIT
    Using
    AutoCAD 2015
    Join Date
    Apr 2010
    Location
    Rochester NY
    Posts
    180
    Default
    Hi Atticus,
    I have my own method but it is really hard way. I attached a pdf to explain my method.
    Have a nice day
    Pascal
    Any constructive criticism to improve my method are welcome
Similar Threads
  1. converting xref file fr. CTB to STB Issues!!
    By crosscad in forum AutoCAD Beginners' Area
    Last Post: 4th Jun 2009, 05:41 pm
  2. Converting Mesh to Solid?
    By shift1313 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Nov 2008, 09:44 pm
  3. Converting a wireframe to solid
    By AutoNewbie in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Mar 2008, 02:08 pm
  4. converting 3D figure into solid
    By gib65 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Nov 2007, 10:21 pm
  5. Converting 3D face to 3D solid
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 6th Feb 2007, 03:42 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
