Atticus Posted May 28, 2010 Share Posted May 28, 2010 Already looked around for a solution to this problem, but have yet to figure it out. I'm newish to AutoCAD (dabbled off and on, but mostly in 2d) but a quick learner. Basically I'm designing a quarter spiral staircase, more specifically, the stringer to support them. This isn't the final model of the stringer I will be using, but to be able to convert this back into a solid will be helpful so I can subtract other parts of the staircase from it. The original solid was created using thicken from a 2d polyline converted into a region. I then subtracted a piece from it, exploded the 3d solid and reshaped the wireframe into what you see in my DWG. I cant seem to turn it back into a 3d solid. CONVTOSOLID gives me a "Cannot convert an open curve" error. I'm pretty sure that the model is closed, but like I said, newish to AutoCAD, and not sure exactly how to check. Ive been reading (and learning alot from) these forums for a while now, and this is the first issue that I wasn't able to find a solution for. Maybe I'm just not asking the search engine the right questions - and apologies if this is a repost in sheep's clothing. stringer.dwg Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 28, 2010 Share Posted May 28, 2010 exploded[/b] the 3d solid and reshaped the wireframe into what you see in my DWG. Ive been reading (and learning alot from) these forums for a while now' date=' ...[/quote'] You should have read to never never never explode a solid (or at least make a backup file first). Quote Link to comment Share on other sites More sharing options...
kencaz Posted May 28, 2010 Share Posted May 28, 2010 I used press-pull to extrude and again to cut the angles... Have you tried it yet...? KC Quote Link to comment Share on other sites More sharing options...
Atticus Posted May 28, 2010 Author Share Posted May 28, 2010 You should have read to never never never explode a solid (or at least make a backup file first). why shouldn't I explode a 3D object? and up try the press pull when I get home, just starting my shift. Quote Link to comment Share on other sites More sharing options...
rvpas Posted May 31, 2010 Share Posted May 31, 2010 Hi Atticus, I have my own method but it is really hard way. I attached a pdf to explain my method. Have a nice day Pascal Any constructive criticism to improve my method are welcome How to transform wireframe to solid.pdf Quote Link to comment Share on other sites More sharing options...
