Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 22
  1. #11
    Full Member
    AutoCAD 2015
    Sep 2011
    Tulsa, OK
    26
    Smile Sweeeet!
    Quote Originally Posted by Tommy78 View Post
    to remove the datalink from your xref manager:
    1) rename or remove the linked .dxe files
    2) copy/paste this:
    Code:
    (dictremove (namedobjdict) "ACAD_DATALINK")
    in the commandline, ENTER
    3) save and close the drawing, reload drawing
    this works in 2009, don't know if it works in 2010
    Worked like a charm but NOT until i saved, closed, and reopened! Thanks!!!
  2. #12
    Junior Member
    daha's Computer Details
    Windows 7 Prof
    HP Z400
    6 GB
    Electrical
    daha's Discipline Details
    CAD Spec.
    Electrical
    Audio Visual Design & Installation
    AutoCAD 2010
    Jan 2013
    US-AZ
    14
    I have the same issue; a base dwg with a ton of xrefs from clients and a ton of DXE data links that are no longer valid and you can't purge them. I've tried...(dictremove (namedobjdict) "ACAD_DATALINK") But all that did was remove the datalink dictionary entirely (didn't touch the DXEs). I've tried the dictEdit.lsp...that had no affect. It runs and shows a list of datalinks but not the DXEs of course. I tried wblocking the entire dwg, didn't work. I went in to each of the damn xrefs to find when these DXEs show up, and I've identified that. But I still have no clue as to how to get rid of these things. These ghost data links must be getting read from somewhere?? What table is being read that populates XREF Manager? If it's showing up as links there, then it has to be in the dwg database somewhere. What about "super purge?" Is that still available?
  3. #13
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,744
    I think SP is available yes. Though I just want to make sure I'm understanding correctly. The DXE is simply a file, you can delete it in Windows Explorer.
    If you mean that the DXE is still listed as linked, then it's most probably a situation of one (or more) of the xref containing the links. You'll need to open each xref in turn, clear the dictionaries from there, save, close reload, next. Until you've "cleaned" all the xrefs, then to be sure, clean the container DWG too. save close and reopen.
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  4. #14
    Senior Member ammobake's Avatar
    ammobake's Computer Details
    Windows 7 Pro 64bit
    HP 2240 SFF Workstation
    HP
    Intel Xeon CPU E3-1225 v5 @ 3.30ghz, 3.30ghz
    18 GB RAM
    Nvidia NVS 510
    Confidential
    Confidential
    4 total (2 - 27 in monitors below, 2- 22 in monitors on top)
    Construction
    ammobake's Discipline Details
    CAD Drafting & Architecutural Design (gov/military)
    Construction
    AutoCAD 2017
    Mar 2008
    Fairbanks, Alaska
    201
    This thread was helpful for me on Autocad 2014 also - Just used this approach today.
    I was using a pre-existing drawing set for a new project design. The XREF manager showed the pre-existing data link on the list but apparently XREF manager doesn't let you detach or remove if the data link is deleted at some point.
    This particular data link was a portion of an excel document that was copied and pasted into Autocad.
    -Chris
  5. #15
    Forum Newbie
    AutoCAD 2014
    Jan 2014
    1
    Default Thanks!!!!!!!!!!!!!
    Seems like the Excel Data Link was inserted straight into the drawing but if you make a xref it will be no problem. But this help thankssss!!!!!!
  6. #16
    Forum Newbie
    AutoCAD 2013
    Dec 2014
    1
    2) copy/paste this:
    Code:
    It works in 2013
  7. #17
    Senior Member Dinochrome's Avatar
    Dinochrome's Computer Details
    Win 10
    Dell M6600 (no CAD)
    64-bit Intel Xenon Multi-threading
    16 Gig
    NVIDIA Quadro 3000M
    laptop
    Education
    Dinochrome's Discipline Details
    ...gone trucking
    Education
    not applicable
    Feb 2014
    America's Hinterland
    105
    2) copy/paste this:
    Code:
    Thanks Tommy78!
  8. #18
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    ... or you could just use the DATALINK command.
    Drafting is a breeze.
  9. #19
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,884
    Quote Originally Posted by RobDraw View Post
    That doesn't work as far as I could tell, I just went through this a couple of weeks ago. Hopefully though, you are correct for newer versions of AutoCAD.
  10. #20
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    It's a two step process. The table needs to be deleted, then the datalink removed.
  1. adding data to polyline and extracting this data to table?
    By feargt in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th May 2013, 08:04 pm
  2. Replies: 2
    Last Post: 19th Aug 2009, 02:40 pm
  3. Excel Table Data Link
    By johnv in forum AutoCAD General
    Last Post: 31st Jul 2009, 12:11 am
  4. How can I edit a Table Data Link Value via VBA or LISP?
    By PJF in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Feb 2009, 03:28 pm
  5. Edit Table with Data Link
    By Tconn in forum AutoCAD General
    Last Post: 25th Sep 2008, 02:20 pm
