Results 1 to 4 of 4
    Senior Member Bobzy20's Avatar
    Bobzy20's Computer Details
    Windows 7 Ultimate (x64)
    Advent T9509
    Foxconn G9657MA-8KS2H
    Intel Core 2 Quad Q6600
    8GB DDR2 PC2-5300
    Nvidia Quadro FX580 512MB
    320GB SATA
    WD 1TB SATA
    Advent X19w 19" Monitor
    Electrical
    Bobzy20's Discipline Details
    Lighting Controls CAD Technician
    Electrical
    AutoCAD 2014
    Aug 2009
    Middlesex, UK
    397
    Default Where has my 3D Move Gizmo gone?
    Hi guys I wonder if you can help me with this small issue I’m having.
    I’m currently running through this 3D Mesh Tutorial on YouTube:
    http://www.youtube.com/watch?v=tI5EyFw4agM
    Whenever I select the Mesh object I’m drawing my Gizmo doesn’t appear.
    DEFAULTGIZMO is set to value 0
    GTAUTO is set to value 1
    Any help would be great.
    Thanks
    Bobzy20
    Apparently Revit is the FUTURE but all I know is AutoCAD.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    What is your shademode?
    Senior Member rvpas's Avatar
    rvpas's Computer Details
    Seven Pro
    laptop HP EliteBook 8760w - workstation hp
    Architectural
    rvpas's Discipline Details
    building CAD designer and AUTOCAD ATC instructor free lance
    Architectural
    Help to design building with architect work with REVIT and AUTOCAD during the step of conception, follow the contruction site, building survey. ATC Instructor with trainng center 2d 3d AUTOCAD and REVIT
    AutoCAD 2015
    Apr 2010
    Rochester NY
    180
    Hi,
    Change your visual style to 3d wireframe
    Home tab/View panel/select 3d wireframe
    see the differente between 2D and 3D wireframe
    In 2D no gizmo see image below
    bye
    Pascal
    Advent T9509
    8GB DDR2 PC2-5300
    320GB SATA
    WD 1TB SATA
    Electrical
    Electrical
    AutoCAD 2014
    Aug 2009
    Middlesex, UK
    397
    Thanks very much for that guys that worked well.
    I also noticed under the Render tab in the tutorial he has a panel called ‘Edge Effects’ but I don’t seem to have that, how can I add that panel in?
    Thanks
    Bobzy20
  1. Gizmo not there.
    By funk in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th May 2010, 12:50 am
  2. Gizmo not shown on dwg.
    By pedzcabz in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Aug 2009, 01:55 am
  3. Text Justification - Move vs Non-Move
    By ILoveMadoka in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th May 2009, 08:40 pm
  4. where's my gizmo?
    By jasoooon in forum 3D Modelling
    Last Post: 31st Mar 2009, 07:26 am
  5. New 2007 Cursor gizmo??
    By zronn in forum AutoCAD General
    Last Post: 31st Aug 2006, 05:17 pm
