Results 1 to 9 of 9
    Forum Newbie
    Inventor 2008
    Jun 2010
    5
    Default Problems Embossing a Sketch
    I am relatively new to AutoCAD Inventor 2008 and I have hit a snag.
    I have designed a fairly complex part and when I try to Emboss (1mm) a Sketch I get an error message (Sketch Doctor) telling me I have an Open Loop in my profile, but I cannot find the problem.
    If I create a new part and then copy and paste the Sketch, I can Emboss it with no problem at all. Any ideas what's causing the error? I can email the design if anyone can help me.
    Thanks, John.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    Drag the red End of Part marker to the top of the browser hiding all features.
    Save the file.
    In Windows Explorer right click on the file name and select Send to Compressed (zipped) folder.
    Attach the resulting *.zip here.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Forum Newbie
    Inventor 2008
    Jun 2010
    5
    Default Inventor Zip File
    Zip file attached. THX, John.
    Zip File is too large to upload (1,554KB)
    Last edited by John Atkinson; 3rd Jun 2010 at 04:26 pm. Reason: Zip File not attached
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    Quote Originally Posted by John Atkinson View Post
    File too large to upload (1,554KB)
    Did you roll up the EOP before zipping as I directed?
    Try this - delete everything but the sketch you are trying to use to emboss, then roll up the EOP and attach. (make sure you are working on a back-up of the file)
  5. #5
    Forum Newbie
    Inventor 2008
    Jun 2010
    5
    I rolled it up to above the first extrusion, directly below "Origin". Can I email the file to you?
  6. #6
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    Delete everything except the sketch - surely the sketch is not over 1Meg?
  7. #7
    Forum Newbie
    Inventor 2008
    Jun 2010
    5
    Default Problem Solved ????
    In trying to reduce the file to a manageable size I found that by deleting various sketches I was able to emboss the sketch as desired. Perhaps the other sketches were obstructing the selection of the profile to be embossed and by deleting them I was able to perform the emboss function.
    Thanks for your effort to help anyway. John.
  8. #8
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    You probably could have simply turned off the visibility of other sketches rather than delete.
  9. #9
    Forum Newbie
    Inventor 2008
    Jun 2010
    5
    Yes, after I had deleted some of the sketches to reduce the file size the penny dropped and I turned of the visibility on the others, except for the one I wanted to emboss.
    Thanks again for your help, John.
  1. Need Help With 3D Sketch
    By Uncle Harley in forum Autodesk Inventor
    Last Post: 27th Aug 2009, 12:57 am
  2. inventor sketch to autocad sketch posible?
    By matulja87 in forum Autodesk Inventor
    Last Post: 11th Aug 2009, 03:11 pm
  3. Embossing Text
    By DaleLloyd7569 in forum Autodesk Inventor
    Last Post: 22nd Jun 2009, 10:38 pm
  4. Replies: 6
    Last Post: 8th Jan 2009, 06:47 pm
  5. first sketch
    By JBullseye74 in forum SketchUp
    Last Post: 12th Apr 2006, 12:03 am
