Results 1 to 3 of 3
Thread: nut
    Forum Newbie
    Inventor 2010
    Apr 2010
    8
    Default nut
    How do i place a edge on the top/bottom nut section on this stem.I tried by using Extrude command and selecting Intersect + 45 degree angle Taper.When i used this combination it places the Taper on the nut but removes the rest of the part.Can this be done or do i need to create the Nut and Taper first and then do sketches/Extrude for the rest.
    Cheers....Pete
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    Always do the Hex extrusion first.
    Then the Extrude(s) taper intersection(s)
    Then finish the part cylindrical shaft(s).
    Your other option is to do a Revolve - Cut on the hex.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Forum Newbie
    Inventor 2010
    Apr 2010
    8
    Thanks for the advice
