Results 1 to 8 of 8
    Forum Newbie
    Map 3D 2008
    Jun 2010
    3
    Default Clearance checking?
    Hello gang,
    Quick question of which I think I already know the answer to:
    Is there a way to check clearances between 2 3D solids in Autocad?
    Thanks.
    Jason
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    You want to see if they collide? Try using the Interfere command.
    Forum Newbie
    Map 3D 2008
    Jun 2010
    3
    No the objects im checking have to have a minimum clearance of 18 inches. the surfaces are not coplanar and are also at different elevations and angles so its not always east to see what edge of these objects are "closest" in relation to one another.
    hoping for a cmd that would find that point automatically and list the distance from one another.
    Jason
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Sorry...can't help you there. I use "cheaters" (i.e. - little line segments) attached to critical points and do a "list" on them. I'm sure there is a better way and someone will soon come by and educate us both.
  5. #5
    Forum Newbie
    Map 3D 2008
    Jun 2010
    3
    Hope so!
    anyone else know if this can be done?
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    It appears we have a lack of viable solutions at the moment. Let's get this thread back in the limelight and see if it attracts any attention. ***BUMP***
  7. #7
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Try to perform some SECTIONs along those objects - this may help in some case; depends of their geometry.
    Regards,
  8. #8
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Autodesk Inventor Minimum Distance.
    Might check free Inventor Fusion http://labs.autodesk.com and see if it has the tool as well.
    Last edited by JD Mather; 4th Jun 2010 at 08:15 pm. Reason: see if it attracts any attention
  1. Checking a drawing for Attributes
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th May 2009, 07:34 pm
  2. Region checking
    By AcmeMan in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Dec 2006, 10:40 am
  3. checking the polylines
    By vivekgrs in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Sep 2006, 05:12 am
