Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 38
    Junior Member
    AutoCAD 2007
    Apr 2010
    14
    Question Inquiry: Station Labeling
    If anyone could direct me as to what code is needed to increase a station value.
    The attached lisp references an earlier thread (http://www.cadtutor.net/forum/showth...light=chainage)
    I have attached the converted lisp file and my working dwg
    Thanks
    Super Member fixo's Avatar
    fixo's Computer Details
    Windows 7
    E7500
    Intel(R)Core(TM)2 DUO CPU 2.93HGz
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Pietari, Venäjä
    1,586
    Quote Originally Posted by runner214 View Post
    Thanks
    This one is from oldies I don't remember how it works
    It was written for one fellow from Croatia as I remember it
    Code:
    ;; written by Fatty T.O.H. ()2004 * all rights removed
    ;; edited 6/5/10
    ;; Stationing
    ;;load ActiveX library
    (vl-load-com)
    ;;local defuns
    (defun start (curve)
      (vl-catch-all-apply (function (lambda()
      (vlax-curve-getclosestpointto curve
      (vlax-curve-getstartpoint curve
    (defun end (curve)
      (vlax-curve-getendpoint curve
    (defun pointoncurve (curve pt)
      pt
    (defun paramatpoint (curve pt)
      (vlax-curve-getparamatpoint curve
      pt
    (defun distatpt (curve pt)
      (vlax-curve-getdistatpoint curve
        (vlax-curve-getclosestpointto curve pt)
    (defun pointatdist (curve dist)
      (vlax-curve-getpointatdist curve dist)
    (defun curvelength (curve)
      (vlax-curve-getdistatparam curve
      (- (vlax-curve-getendparam curve)
         (vlax-curve-getstartparam curve)
    (defun distatparam (curve param)
      param
    (defun statlabel (num step)
    ;; num - integer, zero based
    ;; step - double or integer, must be non zero
                (strcat
         (itoa (fix (/ num 2.)) )
         (rtos (* (* step 2) (- (/  num 2.) (fix (/ num 2.)))) 2 2)
    (defun insertstation (acsp bname pt rot tag num step / block)
      (vl-catch-all-apply
        (function (lambda()
         (setq block (vlax-invoke-method acsp 'InsertBlock pt bname 1 1 1 rot))
      (changeatt block tag (statlabel num step))
    block
    (defun changeatt (block tag value / att)
      (setq atts (vlax-invoke block 'GetAttributes))
      (foreach att atts
        (if (equal tag (vla-get-tagstring att))
          (vla-put-textstring att value)
    ;;// written by VovKa (Vladimir Kleshev)
    (defun gettangent (curve pt)
      (setq param (paramatpoint curve pt)
            ang ((lambda (deriv)
         (if (zerop (cadr deriv))
           (/ pi 2)
           (atan (apply '/ deriv))
        (cdr (reverse
        (vlax-curve-getfirstderiv curve param)
      ang
    (defun c:st50 (/ acsp adoc block blkdef cnt en ent label lastp
              leng mul nop num pt rot sign start step)
      (setq adoc (vla-get-activedocument (vlax-get-acad-object))
        acsp (vla-get-block (vla-get-activelayout adoc))
     (if (not (tblsearch "block" "Station"))
         (alert "Block \"Station\" does not exist. Error...")
         (exit)(princ)
      (setq blkdef (vla-item (vla-get-blocks adoc) "Station"))
      (setq nop T)
      (vlax-for item blkdef
        (if (not (and (eq "AcDbAttributeDefinition" (vla-get-objectname item))
          (eq "NUMBER" (vla-get-tagstring item))))
          (setq nop nil)
       (if nop
         (alert "Block \"Station\" has not attribute \"NUMBER\". Error...")
         (exit)(princ)
    (setq step 50.)
    (if
      (setq
        ent (entsel
       "\nSelect curve near to the start point >>"
         (setq en (car ent)
        pt (pointoncurve en (cadr ent))
        leng (distatparam en (vlax-curve-getendparam en))
         (setq num (fix (/ leng step))
         (setq mul (- leng (* num step))
         (if (not (zerop mul))
           (setq lastp T)
           (setq lastp nil)
         (if (> (- (paramatpoint en pt)
            (paramatpoint en (vlax-curve-getstartpoint en))
         (- (paramatpoint en (vlax-curve-getendpoint en))
      (setq start leng
            sign  -1
      (setq start (distatparam en (vlax-curve-getstartparam en))
            sign  1
         (vla-startundomark
         (setq cnt 0)
         (repeat (1+ num)
           (setq pt  (pointatdist en start)
          rot (gettangent en pt)
          (setq block
          (insertstation acsp "Station"
            (vlax-3d-point pt)
            rot
            "NUMBER" cnt step)
           (setq cnt   (1+ cnt)
          start (+ start (* sign step))
      (if lastp
        (if (= sign -1)
          (setq pt  (vlax-curve-getstartpoint en)
          (setq pt  (vlax-curve-getendpoint en)
          (setq block
            (vlax-3d-point pt)
            rot
            "NUMBER" (1- cnt) 0)
        (setq label (statlabel (1- cnt) 50.)
       label (strcat (substr label 1 (1+ (vl-string-search "+" label)))
       (rtos mul 2 2))
        (changeatt block "NUMBER" label)
         (vla-endundomark
       (princ "\nNothing selected")
    (prompt "\n   >>>   Type ST50 to execute...")
    (prin1)
    ~'J'~
    The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
    Junior Member
    AutoCAD 2007
    Apr 2010
    14
    Default Help Appreciated
    Thank you fixo, works fine.
    Appreciate you finding the time to help.
    Senior Member stevesfr's Avatar
    stevesfr's Computer Details
    Vista <ugh>
    HP Pavilion
    Dell Trinitron
    AutoCAD 2008
    Jan 2009
    Central Illinois, USA
    270
    Quote Originally Posted by fixo View Post
    Code:
    ;; edited 6/5/10
    ;; Stationing
    (vl-load-com)
    ;;local defuns
    (defun end (curve)
      pt
      pt
      param
                (strcat
      (vl-catch-all-apply
        (function (lambda()
    block
      (foreach att atts
           (/ pi 2)
        (cdr (reverse
      ang
         (exit)(princ)
      (setq nop T)
          (setq nop nil)
       (if nop
         (exit)(princ)
    (setq step 50.)
    (if
      (setq
        ent (entsel
         (setq en (car ent)
           (setq lastp T)
           (setq lastp nil)
      (setq start leng
            sign  -1
            sign  1
         (vla-startundomark
         (setq cnt 0)
         (repeat (1+ num)
          (setq block
            (vlax-3d-point pt)
            rot
            "NUMBER" cnt step)
           (setq cnt   (1+ cnt)
      (if lastp
        (if (= sign -1)
          (setq block
            (vlax-3d-point pt)
            rot
       (rtos mul 2 2))
         (vla-endundomark
    (prin1)
    ~'J'~
    This is pretty neat. In order for this to work, make a block called STATION with one attribute called NUMBER
    the block can be just a short vertical line with the attribute above the vertical line, the insertion point of the block can be the bottom of the short vertical line. Save the block as STATION and window the short vertical line and the attribute called NUMBER.
    Cheers !!
    Steve
  5. #5
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Pietari, Venäjä
    1,586
    You're welcome
    ~'J'~
  6. #6
    Junior Member
    AutoCAD 2007
    Apr 2010
    14
    Default Question
    Is there anyway the block can be pre-loaded or code added to create the block 'station' ?
  7. #7
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Pietari, Venäjä
    1,586
    Try edited lisp instead
    Code:
    ;; edited 6/5/10
    ;; Stationing
    (vl-load-com)
    ;;local defuns
    (defun makeblock (adoc aprompt atag bname txtheight tstyle / at_obj blk_obj lay line_obj tst)
    (if (not (tblsearch "block" bname))
      (setq tst (getvar "textstyle"))
      (setvar "textstyle" tstyle)
      (setq lay (getvar "clayer"))
      (setvar "clayer" "0")
      (setq blk_obj (vla-add (vla-get-blocks adoc) (vlax-3d-point '(0. 0. 0.)) bname))
      (setq line_obj (vlax-invoke blk_obj 'Addline '(0. 0. 0.) (list 0. 12.0 0.)))
      (vla-put-color line_obj acyellow)
      (setq at_obj (vla-addattribute blk_obj
       txtheight
       acattributemodeverify
       aprompt
       (vlax-3d-point '(-0.5 1. 0.))
       atag
       "0+0.00")
      (vla-put-rotation at_obj (/ pi 2))
      (vla-put-color at_obj acwhite)
      (mapcar (function (lambda(x) vlax-release-object x))
       (list at_obj line_obj blk_obj )
      (setvar "clayer" lay)
      (setvar "textstyle" tst)
    (defun end (curve)
      pt
      pt
      param
                (strcat
      (vl-catch-all-apply
        (function (lambda()
    block
      (foreach att atts
           (/ pi 2)
        (cdr (reverse
      ang
              lay leng mul nop num pt rot sign start step)
      (setvar "dimzin" 2)
       (makeblock adoc "NUMBER" "NUMBER" "Station" 2.0 "Standard")
    (setq step 50.)
    (if
      (setq
        ent (entsel
         (setq en (car ent)
           (setq lastp T)
           (setq lastp nil)
      (setq start leng
            sign  -1
            sign  1
         (vla-startundomark
         (setq cnt 0)
         (repeat (1+ num)
          (setq block
            (vlax-3d-point pt)
            rot
            "NUMBER" cnt step)
           (setq cnt   (1+ cnt)
      (if lastp
        (if (= sign -1)
          (setq block
            (vlax-3d-point pt)
            rot
       (rtos mul 2 2))
         (vla-endundomark
    (prin1)
    ~'J'~
  8. #8
    Junior Member
    AutoCAD 2007
    Apr 2010
    14
    Default Thanks
    Thanks fixo - that did the trick!
  9. #9
    Vista <ugh>
    HP Pavilion
    Dell Trinitron
    AutoCAD 2008
    Jan 2009
    270
    Angry
    Really need to flip the block 180 degrees.
    when "walking" along the line to which stationing is assigned
    you have to read upside down !!
    just my opinion and 2 cents
    of course one could use the first version and make their own block.
    S
  10. #10
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Pietari, Venäjä
    1,586
    Quote Originally Posted by stevesfr View Post
    S
    Hi Steve, I don't know an imperic standards
    Can you fix what you said?
    ~'J'~
  1. Horizonal Alignment Lisp Inquiry
    By runner214 in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Apr 2010, 08:50 am
  2. Inquiry Units in ACAD 2004
    By philip mccollum in forum AutoCAD General
    Last Post: 26th Nov 2009, 05:09 pm
  3. Annotative Inquiry
    By RyanAtNelco in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Sep 2009, 05:09 pm
  4. an inquiry
    By DaveIsHereNow in forum AutoCAD Beginners' Area
    Last Post: 1st Jan 2009, 01:31 pm
  5. TrueView - inquiry scale
    By funky fedaykin in forum Autodesk Software General
    Last Post: 4th Sep 2008, 01:49 am
