Results 1 to 4 of 4
    Full Member
    not specified
    Oct 2005
    37
    Default only one object is selected
    hello every one
    Hi, I am using autocad 2002 and now i am getting a problem with the selection items.
    whn i select two or more item(drawing objects like line,circle,arc etc........) for copy or move or mirror then only the last selected item is being performing the specified operation.
    why is it happening so, why is the operation tat i perform is not applied for all the object.
    thanku
    bye
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Hello Kanyakumari_t!
    Possible your AutoCAD is set to use the shift key to add new items to a selection set.
    Try this:
    Start a command (say MOVE).
    Select the first object.
    Press and hold SHIFT and select the next object(s).
    Relase the SHIFT key and press ENTER to terminate the selection.
    Continue the command as usualy.
    If it works you may try to reset the normal settings:
    Go to TOOLS > OPTIONS and select the SELECTION pannel. Remove the checkmark near the USE SHIFT TO ADD TO SELECTION
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    The PICKADD system needs to be set to 1 to allow multiple selections. Fuccaro's menu selection may have the same effect (changes the variable).
    Full Member
    not specified
    Oct 2005
    37
    hello Fuccaro and CarlB,
    ur suggestions helped me
    thanku
