+ Reply to Thread
Results 1 to 4 of 4
Thread: How to plot
  1. #1
    Forum Newbie
    Using
    AutoCAD 2010
    Join Date
    Feb 2010
    Posts
    1
    Default How to plot
    Hi,
    Im a newbie to Autocad and have some printing problems.
    When I go to the layout1 tab and draw a new viewport, my whole drawing is set in it. So far so good, when I go to preview it is totally blank. Do you have suggestions what could solve this problem? Thank you.
  2. #2
    Forum Deity rkent's Avatar
    Computer Details
    rkent's Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    Dell Precision T7500
    CPU:
    Xeon Dual Core E5503 2.0Ghz
    RAM:
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    Graphics:
    nVidia Quadro 3800
    Primary Storage:
    300Gb, 10K rpm
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    rkent's Discipline Details
    Occupation
    Facilities Design - Semi-conductor manufacturing
    Discipline
    Mechanical
    Details
    Designer: Process Piping, P&ID's, Machine Part Design, Planning / General Arrangement. Facilities Management. Drafting: Electrical, Controls, Architectural.
    Using
    Mechanical 2014
    Join Date
    Nov 2007
    Location
    Lat:35, Long:-106, Elev: 5164'
    Posts
    3,401
    Default
    Are you specifying the area to plot by layout, window, extents, etc?
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  3. #3
    Junior Member skarfac3's Avatar
    Using
    AutoCAD 2010
    Join Date
    Oct 2008
    Posts
    14
    Default
    Quote Originally Posted by hoki View Post
    Hi,
    use the command PAGESETUP.
  4. #4
    Full Member einstainas's Avatar
    Using
    AutoCAD 2010
    Join Date
    Jan 2009
    Posts
    50
    Default
    i know how to plot.but its realy hard to explain literaly ,cause you need adjust many option.
    i suggest read a book, also you can wach tutorial video.
Similar Threads
  1. Plot filename and date at the end of each plot
    By sadhu in forum AutoCAD Beginners' Area
    Last Post: 20th May 2010, 03:32 pm
  2. Plot Device/Plot Settings Tab
    By Rudbeckia in forum AutoCAD Beginners' Area
    Last Post: 11th Mar 2010, 03:33 pm
  3. Changes to plot layout and plot file for publish
    By GliderRider in forum AutoCAD Drawing Management & Output
    Last Post: 12th Mar 2009, 09:48 pm
  4. Plot with plot styles
    By Lucas_ in forum AutoCAD Beginners' Area
    Last Post: 23rd Jun 2008, 05:30 am
  5. plot file locations for batch plot?
    By Kate M in forum AutoCAD General
    Last Post: 29th Oct 2003, 09:43 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
