Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Qselect
    Senior Member alijahed's Avatar
    alijahed's Computer Details
    Windows 7
    DELL M4500
    Inventor 2012
    Apr 2007
    Cape Town/South Africa
    386
    Default Qselect
    Hi All,
    how can I use QSELECT command in lisp and set its parameters to select a specific block through block name filter.
    Cheers
    Ali
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Look into using ssget instead.
    Windows 7
    DELL M4500
    Inventor 2012
    Apr 2007
    386
    I have dynamic blocks so I prefer to use QSELECT.
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,008
    QSelect doesn't have a commandline option.
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  5. #5
    Civil 3D 2011
    Apr 2008
    6,008
    If you want to roll your own, you can specify the block name and cycle through a selection (removing what doesn't match the vla-get-effectivename) and the use sssetfirst to select what's left.
    Code:
    (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat "`*U*," name))))
    This will select all dynamic blocks and blocks matching the specified name. From there, you can cycle (what I said above).
  6. #6
    Windows 7
    DELL M4500
    Inventor 2012
    Apr 2007
    386
    After weeks I came back to this and I confused!
    so it is better to simplify the situation.
    Let's say I have a dynamic block inserted on the screen and I know the name of the dynamic block.
    How can I select that dynamic block by it's name?
    Cheers
    Ali
  7. #7
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,627
    Ali,
    you can filter any Entity you want with Autolisp, but to put selection on hold is not that needed, so there must be an action to do after selecting any Entity.
    For example this lisp is made by me it will ask you to select a block and it will insert the selected Block with non stop action until you hit enter. Try it.
    Code:
    (defun c:qs (/ a ins)
    (setq b (cdr(assoc 2 (entget(car(entsel"\nSelect a Block: "))))))
    (while (setq ins (getpoint"\n Insertion point <enter to exit> :"))
    	(command "_insert" b ins  "" "" "" ))
    (princ "Written by Tharwat")
    (princ))
    Tharwat
  8. #8
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,627
    Hi
    Your question is not clear and to whom it is dedicated ?
    clarify please
    Tharwat
  9. #9
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,729
    Quote Originally Posted by alijahed View Post
    When a dynamic blocks properties are altered, it becomes an anonymous block, therefore you are unable to select it using its name in an ssget filter, rather, use the filter that Alan has suggested, and filter through the resultant set (should there be one), and check against the EffectiveName property.
    Lee Mac Programming
    Just another Swamper
  10. #10
    Full Member
    AutoCAD 2012
    Jul 2010
    Dublin Ireland
    50
    Sorry to gravedig here . I need to be able to select a block and have AutoCAD tell me how many times that block has been placed in the drawing file. Tharwat's routine looks like it could be altered to do this - but I have no idea how to do so. Can anyone assist please ?
  1. Qselect Wildcards
    By qball in forum AutoCAD General
    Last Post: 13th Jan 2011, 03:32 pm
  2. How QSELECT functioning?
    By Billy in forum AutoCAD General
    Last Post: 23rd Feb 2010, 03:09 pm
  3. Qselect
    By dhl in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Nov 2009, 11:02 am
  4. qselect and filters
    By robcad in forum AutoCAD Drawing Management & Output
    Last Post: 11th May 2007, 02:23 pm
  5. QSELECT in transparency mode??
    By StykFacE in forum AutoCAD Drawing Management & Output
    Last Post: 7th Mar 2007, 11:31 pm
