Flag for Overlay vs. Attachment
CHLUCFENG
For XREF's, I want to change overlays to attachments. Can someone tell me the dotted pair that denotes which is which?
I use this get.lsp fuction from an old AutoLisp book I had:
(defun c:get ()
 (SETQ ENT (ENTSEL))
 (SETQ ENT1 (ENTGET (CAR ENT)))
 (SETQ CT 0)
 (TEXTPAGE)
 (PRINC "\n  ENTGET OF SELECTED ENTITY:")
 (REPEAT (LENGTH ENT1)
   (PRINT (NTH CT ENT1))
   (SETQ CT (1+ CT)))
For the 70 bitcode, I get (70 . 0) for both Xref's that are attached and Xref's that are overlayed. Shouldn't I be getting a different value for one of them?
Bit coded group 70 in the block definition table :)
(defun GetBlockFlag ( blockname )
 (if (setq def (tblobjname "BLOCK" blockname))
   (cdr
     (assoc 70
       (entget def)
Ah....
(70 . 36) = attached
(70 . 44) = overlay
Thank You, Domo Arigato, Muchas Gracias, and Cheers...
Chuck
Slightly more complex than that...
(defun isXRef ( blockname )
 (= 4 (boole 1 4 (GetBlockFlag blockname)))
(defun isOverlay ( blockname )
 (= 8 (boole 1 8 (GetBlockFlag blockname)))
   (cdr
     (assoc 70
       (entget def)
I did the manual "double click" on all the overlays within some building plans yesterday. I am working on automating that portion for future updates from that architect. Had to start with which parameter to change.
I plugged your code into the get function:
(defun GetBlockFlag ();\ blockname)
 (setq blockname (cdr (assoc 2 ENT1)))
 (if (= (cdr (assoc 0 ENT1)) "INSERT")
     (cdr (assoc 70 (entget def)))
(defun c:get ()
 (SETQ ENT (ENTSEL))
 (SETQ CT 0)
 (TEXTPAGE)
   (SETQ CT (1+ CT)))
 (getblockflag)
I am still getting an error, but was able to copy/paste portions to the text editor to get the resulting values. I'm still trying to fix it up.
(defun c:get ( / ss ) ;; Lee Mac
 (if (setq ss (ssget "_+.:E:S" '((0 . "INSERT"))))
   (print
     (GetBlockFlag
       (cdr
         (assoc 2
           (entget (ssname ss 0))
(defun GetBlockFlag ( blockname ) ;; Lee Mac
   (cdr
     (assoc 70
       (entget def)
You are quick!!!
I do like your logic, "AND"ing the values to for isXREF, and isOverlay. Very clever.
Thanks again,
Chuck
