bobsy852 Posted June 10, 2010 Share Posted June 10, 2010 I have the block of a house (2d - just the elvation) but i need to scale it down to fit between 2 lines. I've looked up scaling on here and found that if i make it a block I can scale it just along the x-axis to make the building thinner but not shorter at the same itme! Now I just need to know how much to scale it by? Anyone know how i can figure this out? Basically I need to work out how far along the building the line i need to scale the building back to is, but how do I work out what scale factor that would be? Thanks everyone Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 10, 2010 Share Posted June 10, 2010 Use SCALE command with Reference option to fit the block between limits (this will scale both X and Y) and after modify the Y scale factor in Properties back to 1. Done! Regards, Quote Link to comment Share on other sites More sharing options...
bobsy852 Posted June 10, 2010 Author Share Posted June 10, 2010 haha ive done it via trial and error now "0.43628" lol, took a while but got there in the end, would still be nice to know if there's an easier way though Quote Link to comment Share on other sites More sharing options...
bobsy852 Posted June 10, 2010 Author Share Posted June 10, 2010 Use SCALE command with Reference option to fit the block between limits (this will scale both X and Y) and after modify the Y scale factor in Properties back to 1. Done! Regards, OMG! the simplest thing ever! hahaha Thanks Msasu! least i know for next time! Quote Link to comment Share on other sites More sharing options...
MSasu Posted June 10, 2010 Share Posted June 10, 2010 You're welcome! Regards, Quote Link to comment Share on other sites More sharing options...
