Results 1 to 8 of 8
    lorenzo
    Default grouping objects
    alright then as no one is going to answer my plot styles question what about this... is there a way of grouping objects together temporarily without turning them into a block?
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,635
    Default Re: grouping objects
    Quote Originally Posted by lorenzo
    Sure, it is called Group. Type GROUP in the command line and follow the on screen instructions/dialog boxes. You give it a name and then select items. You can later add or remove items or explode the group. Good luck.
    F7
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
    Super Member gcp310's Avatar
    not applicable
    Dec 2002
    physicaly - Australia, mentaly - Another Planet
    696
    just a tip, if youuse group for a selection of blocks,and you then explode the group, you will also explode the blocks in that group.
    simply type in the command line group>select the group name,then select remove. this will avoid exploding the blocks.
    Goodluck
    not applicable
    Dec 2002
    696
    while i think of it, using groups is great when you model in 3d and want to "flatten" to 2d using soldraw & solview. group alows you control of many 3d items like bmake or wblock does, but does not interfere when using solview.
  5. #5
    Pitkru
    Default how does group work?
    i have a number of objects, all on different layers (with different colors). i want to group them all under one layer and one color (i dont mind discarding the original individual layers). how do i do this?
    i tried the group command, but i dont see it appear in the layers list box. (and all the original layers are still there).
  6. #6
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,635
    Default Re: how does group work?
    Quote Originally Posted by Pitkru
    1st create the new layer (if you do not have this layer yet) and give it the color you want. Select all of the items to change. When you drag a window or crossing over them (do not have a command envoked) thier grips will appear. Then simply select the layer you want them to be on from the layer drop-down list and then either the color or color by-layer. No need to make a group for this need. Good luck.
    F7
  7. #7
    Pitkru
    f7- many thanks mate! exactly what i was looking for
  8. #8
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,635
    You're welcome.
    Glad it helped.
    F7
