Results 1 to 3 of 3
    Full Member Hogfan's Avatar
    Hogfan's Computer Details
    Windows XP Pro
    Dell Precission 470
    Xeon 3.4ghz dual processors
    3gb ram
    Samsung hd 1600jj/p
    dell
    AutoCAD 2008
    Jul 2008
    USA, Arkansas
    71
    Question Cant figure how to draw background lines.
    I am using AC08 and trying to draw a wall lines behind my products, so it shows that there is a wall back there. Problem is i dont want a dark line, i want it to look like its behind the product. Kinda like a grey dotted line, just so you know there is something back there. Is that the only way is to pick a light color and then change lineweight or am i going in wrong direction here?
    Super Member MikeScott's Avatar
    MikeScott's Computer Details
    XP Pro
    Dell Precision T3400
    2.67 gigahertz Intel Core2 Duo
    2046 Mb
    NVIDIA Quadro NVS 290/ 256MB DDR2
    ST3500418AS/ 500gb (450gb free)
    DELL G2410 (24.0"vis)
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    That's partially correct.. personally, I do those setting in my layer settings so that whenever I want a hidden line, I use the hiddenline layer. That means I don't have to remember specific settings and suchlike, it's always going to be consistent across drawings, etc.
    Changing the color means you probably don't need to change the lineweight (because it'll appear softer with the grey line anyways), but you DO want to change the linetype.
    In the layers window, click on the linetype and select either a dashed line from the existing list there, or click "load" to load more linetypes to select from... then go back-in and reselect the loaded linetype.
    The specifics are a matter of preference though.. you might also want to adjust the lineweight and not change the color, or do both, it's all a matter of what you want as your results. I did a lot of test prionts back in the day until I found something I was comfortable with.
    Full Member Nardino's Avatar
    AutoCAD 2011
    May 2010
    New York, USA
    82
    choose a color for this line in which the ctb file is set to some screening...say 50%
  1. Draw slope lines
    By ghostware in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Mar 2012, 12:35 pm
  2. Replies: 16
    Last Post: 3rd Dec 2008, 03:45 pm
  3. Can't figure this one out - zoom affects my lines!
    By First Draught in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jul 2008, 10:14 am
  4. Background lines with raster images
    By kerrychivers in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Jan 2008, 01:25 pm
  5. Curves go more like lines the more i draw :(
    By Armagedoom in forum AutoCAD Drawing Management & Output
    Last Post: 18th Mar 2007, 11:14 pm
