Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 26
  1. #11
    Super Member qball's Avatar
    Structural
    qball's Discipline Details
    Structural
    Structural / Architectural, Residential, Multi-family, Industrial, Wood frame, Steel, Masonry, Concrete, Tilt-up
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    I just had this problem. I closed and opened the file (for an unrelated issue actually) and now it works fine.
  2. #12
    Forum Newbie
    AutoCAD 2010
    Oct 2010
    1
    Default Copy-to-clipboard-failed
    La opcion que encontre para poder superar este error es:
    convertir el archivo dwg en dxf, cerrarlo y abrir el dxf.
    El inconveniente que encontre es que desabilita los bloques dinamicos.
  3. #13
    Super Member mdbdesign's Avatar
    mdbdesign's Computer Details
    WIN7 U 32 BIT, WIN10 PRO 64 bit
    Homemade
    GIGABYTE G31M-ES2L
    INTEL CORE 2-QUAD-Q6600@2.4GHz
    4 GB
    NVIDIA GeForce 9800 gt 1gb
    WESTERN DIGITAL 500GB
    WESTERN DIGITAL SSD 1TB
    2 - 22" HP + 24" Dell
    Manufacture
    mdbdesign's Discipline Details
    Designing Engineer in Engineering Department
    Manufacture
    Pressure tanks Oil processing & storage equip. Steel mill equip. Telecom towers & equip. Wind turbine towers Power plant structures Structural and miscellaneous steel etc.
    AutoCAD 2017
    Jan 2007
    Courtice, Ontario, Canada
    855
    Translated above:
    The option I found to overcome this error is:
    convert dwg to dxf file, close and open the dxf.
    The drawback I found is that disables dynamic blocks.
  4. #14
    Senior Member
    afrazawan's Computer Details
    windows xp
    acer A1917
    Construction
    afrazawan's Discipline Details
    CAD Designer
    Construction
    Civil 3D 2015
    May 2010
    Abu Dhabi/Pakistani
    251
    i can't get it ok
  5. #15
    Forum Newbie
    MLittle's Computer Details
    Win7
    AutoCAD 2011
    Apr 2011
    Bryson City, NC
    5
    I am experiencing this in 2011. I have been beating my head all day trying to copy and paste from one drawing to another. Today I discovered I get the error every time I try to copy a multileader note. When I look at the properties on these it is listed as "ACAD_PROXY_ENTITY" instead of a multi leader note.
  6. #16
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,960
    Has the drawing been saved back to a previous version? Is this in just a few drawings or all drawings?
  7. #17
    Forum Newbie
    Win7
    AutoCAD 2011
    Apr 2011
    Bryson City, NC
    5
    This occurs in all versions of the same drawing. Yes, this drawing was converted from one format to another. It started as a 2007 drawing and has now been changed to a 2011 format.
  8. #18
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Quote Originally Posted by AJSmith View Post
    trying to copy info from one drawing into another have do this 3 time before and not the 4th time i get the message
    Copy to clipboard failed
    what have a done and how do i fix it???
    many thanks
    Adam
    From the Knowledge Base, autodesk.com
    Issue
    When you copy any object in a drawing file and try to paste it into a new drawing, nothing happens or you receive an error stating that the command is invalid.
    Solution
    Depending on the error, use one of the following two workarounds for this issue:
    If you get the "Invalid" message: On the command line, enter mlinestyle. Click to exit the dialog box. Try to paste again. The error will no longer occur.
    If nothing is pasted: The base drawing that the Copy command is being initialized in is corrupt. Recover the base drawing. Copy the objects again; Paste should now work. For more information about drawing recovery, see the related solutions.
    I found in 2012 Suite that if the Sketchbook Designer is installed the copy/clip and the clipboard (from the Labs) will not work.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  9. #19
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,960
    I am sure this will be resolved before the release of AutoCAD 2111, so just hang in there.
  10. #20
    Super Member MarcoW's Avatar
    MarcoW's Computer Details
    Microsoft Windows 7 Pro 64-bit
    A black one
    Intel Xeon E5520 Quad Core
    8 GB
    NVIDIA Quadro FX 580 - 512MB
    300 GB 10000 RPM
    AutoCAD 2011
    Apr 2009
    The Netherlands
    599
    Sorry to bring an old topic back to life but I was experiencing the problem also "copy to clipboard failed".
    In my case I digged throug the whole drawing and found that there were a few polylines (rectangles) that were causing the problem. So selecting 10000 objects, was no problem but with one of these polylines it did not work.
    So I simply exploded them and can move on.
    I thought I post it here, maybe others can benefit.
    I guess the object itself was somehow corrupted. Recover / audit / purge however did not notice any error.
  1. can,t copy to clipboard
    By motee-z in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 4th Nov 2009, 08:21 pm
  2. Copy an expression to the clipboard
    By jammie in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Mar 2009, 06:44 pm
  3. clipboard
    By ZINC in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jul 2005, 03:32 pm
  4. Slow Copy to Clipboard on some files, not on others?
    By srobinson311 in forum AutoCAD Drawing Management & Output
    Last Post: 27th Jun 2005, 08:22 pm
  5. Copy to Clipboard / Copy with Base Point not working
    By Orbit in forum AutoCAD Drawing Management & Output
    Last Post: 12th Oct 2003, 03:10 am
