Mark_CV3D Posted June 16, 2010 Share Posted June 16, 2010 Hi, I´m using autocad civil 3d 2011 and I made a dwg with transparent hatches and it worked as it should. But now i was going to use the same dwg and print it once again , when suddently my solid hatches aren´t transparent anylonger:( I tried making new transparent hatches in new drawing but the function of the transparency dosent work anymore. Does anyone have a solution for this problem? I took som printscreens on an example and attached to this thread. Thanks! Quote Link to comment Share on other sites More sharing options...
Dana W Posted June 16, 2010 Share Posted June 16, 2010 Did this drawing get saved as a prior version, perhaps? There was no hatch transparency untill CAD 2011. Quote Link to comment Share on other sites More sharing options...
Mark_CV3D Posted June 17, 2010 Author Share Posted June 17, 2010 Hello Dana! No it has not been saved in a prior version. I have tried transparency in new files on civil 3d 2011 templates, as the one in my attachement example, and there is still no transparency.. anyone that has a clue of what the problem comes from? Quote Link to comment Share on other sites More sharing options...
Hirowa Posted October 4, 2010 Share Posted October 4, 2010 Is the problem solve? Have the same... Quote Link to comment Share on other sites More sharing options...
Hirowa Posted October 4, 2010 Share Posted October 4, 2010 Ok found it! Command: transparencydisplay Your's is probably set to Quote Link to comment Share on other sites More sharing options...
Mark_CV3D Posted October 5, 2010 Author Share Posted October 5, 2010 thank u! now its working! Quote Link to comment Share on other sites More sharing options...
Hirowa Posted October 5, 2010 Share Posted October 5, 2010 Great! My pleasure. Quote Link to comment Share on other sites More sharing options...
