harrylucas Posted June 16, 2010 Share Posted June 16, 2010 hi, im going to be honest, i have little expireince in 2D CAD in none whatsoever in 3D Cad. i need to convert my clamp design into 3d, so what i did was convert to polyline then extrude. it worked but came out with no fill, they were just 3d lines. also how do i make the thread into a cylinder? i have no idea! PLEASE HELP!!! Bow-Clamp.dwg Quote Link to comment Share on other sites More sharing options...
kencaz Posted June 16, 2010 Share Posted June 16, 2010 AutoCAD will extrude non closed polylines as surfaces. Use "PEDIT" and "JOIN" them. This will result in a solid... KC Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 16, 2010 Share Posted June 16, 2010 Difficult to tell what you really had in mind. Anything close to this? Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 16, 2010 Share Posted June 16, 2010 Threads can be made using the Helix command. If you check J.D. Mather's website he has a cut threads tutorial (AutoCAD 2007) that you might benefit from. Quote Link to comment Share on other sites More sharing options...
harrylucas Posted June 16, 2010 Author Share Posted June 16, 2010 Difficult to tell what you really had in mind. Anything close to this? [ATTACH]20928[/ATTACH] cheers remark thats it, how do you centre the cylinder into the frame? also can you post the file as a cad.file.. heres my one e-clamp redefined.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 16, 2010 Share Posted June 16, 2010 Re: cylinder location. I changed my UCS, drew a circle then extruded it along a path representing its centerline. Re: your second drawing. 1) The cylinder is too long. It should be 170.00; yours measures 172.7428. 2) Your cylinder sits too low. It has to be moved up. I can post a jpg file but not a drawing file. This is something easy enough to fix on your own. I'm not trying to be mean. Quote Link to comment Share on other sites More sharing options...
harrylucas Posted June 16, 2010 Author Share Posted June 16, 2010 hey thanks but how do i move it up? Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 16, 2010 Share Posted June 16, 2010 Make sure your UCS is oriented in the right direction and use the move command. Type the exact distance in at the command line. Quote Link to comment Share on other sites More sharing options...
harrylucas Posted June 16, 2010 Author Share Posted June 16, 2010 HI is this better? e-clamp redefined.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 16, 2010 Share Posted June 16, 2010 Did you realize you have two cylinders (one copied over the other)? Re: your second redefined drawing. You have a problem. The cylinder is at an angle and it does not touch the clamp at one end (the end where the wing nut is located). There is also a new, much smaller diameter cylinder adjacent to the main one. What's that all about? One more thing. There is a gap between the wing nut and the clamp (0.5616). Quote Link to comment Share on other sites More sharing options...
harrylucas Posted June 16, 2010 Author Share Posted June 16, 2010 no? :L i am rubbish, be forgiveing! Quote Link to comment Share on other sites More sharing options...
harrylucas Posted June 16, 2010 Author Share Posted June 16, 2010 no i didnt i am rubbish be forgiving! :L Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 16, 2010 Share Posted June 16, 2010 I'll show you some mercy. Otherwise I'd have to put you out of your misery. Here is the CAD drawing in 2007 file format. My clamp has different colors than yours. E-Clamp Revised.dwg Quote Link to comment Share on other sites More sharing options...
harrylucas Posted June 16, 2010 Author Share Posted June 16, 2010 Hi thanks for that. This is it now. i was just wondering: a) on the curved section of the frame, that will be acting as a handle , so is there a texture i can use to make it look like rubber/plastic? b) could the rest of the frame be bright green like the JCB colours? cheers, Quote Link to comment Share on other sites More sharing options...
harrylucas Posted June 16, 2010 Author Share Posted June 16, 2010 oh.. here it is e-clamp redefined.dwg Quote Link to comment Share on other sites More sharing options...
harrylucas Posted June 16, 2010 Author Share Posted June 16, 2010 also i did that mathers guys tutorial on threads and every time i try to extrude is say cant extrude non-plannar objects?!?!? i'm using acad07 btw.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 16, 2010 Share Posted June 16, 2010 Substitute the word "materials" for "textures". Portions of your design can be made to appear in a different color if you wish. One method is to use the Color Faces solids editing tool. Non-planar objects? Try the tutorial again and pay close attention to the instructions. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 17, 2010 Share Posted June 17, 2010 I took a look at your drawing attached to post #15 above and you still have some problems. Where to start? The wing nut and threaded rod (a.k.a. - cylinder) are crooked. I suspect that could be a part of the problem you're having with creating threads. I don't know how you are manipulating your UCS but you need to get it under control or you'll continue to have problems with geometry going off at odd angles. Example: it appears your helix does not follow the centerline of your threaded rod. This is evident in both a 2D wireframe and conceptual visual style. To see what I am talking about look at a "Top" view of your drawing rather than using an isometric view. One other item I noticed. The blue/green rectangular block at the wing nut end does not make contact with the clamp itself. It is definitely back to the drawing board for you. Try again. The list keeps growing. It appears you had some problems with the wing nut too. I speak in reference to the fillets around the perimeter. They are incomplete. Were you aware of that? Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 17, 2010 Share Posted June 17, 2010 After you have added threads to the rod will you also be creating the reverse profile on the clamp itself where the rod passes through the wing nut end? Or hadn't you expected to show that level of detail? Re: Your helix. Why are the top and base radii different? One is 5.0000 and the other one is 5.0587. I'm no mechanical engineer but wouldn't the radius be consistent over the length of the threaded rod? How did you determine the number of turns? Your helix has 14. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 17, 2010 Share Posted June 17, 2010 This is what I was able to construct using your geometry. The errors I pointed out in my previous posts have been corrected. Since you did not include a tooth profile I just made one up. Everything is now in alignment. Quote Link to comment Share on other sites More sharing options...
