Results 1 to 9 of 9
Thread: Grids
    Junior Member
    not applicable
    May 2010
    11
    Default Grids
    Is there a way to enter a grid into a drawing? I'm attempting to draw the deck of a barge with a faint grid where the lines are spaced by half meters. do i have to just do the whole thing by hand, or by using the array tool? Or can i just lay a grid overtop of my existing drawing?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,136
    Why not use the Grid command? In 2010, as in previous versions, you'll get a series of dots spaced as per your requirements.
    Another option is to draw a grid using the Array command and give it a light grey color. Then lock the layer it is on.
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    571
    Maybe you want to look at the 'Hatch' command. You could use the 'Net' hatch, rotated and scaled to your desired sizes.
    Super Member Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Independent Architectural Draftsman
    Construction
    Residential Homes, Construction and Renovation
    AutoCAD LT 2009
    Feb 2010
    Chuluota, Florida
    1,770
    You want it to be at a specific separation, and you want it to show on the plot?
    Then I would go with the array. Array a single row across, then array a single column up and down, then finagle the two arrays so they cross properly.
    Definately put it on it's own layer so you can custom color it, and turn it off while working on the boat. I'd also make the grid a block so you can share it with friends.
    Yogi Berra: "In theory there is no difference between theory and practice. In practice there is."
  5. #5
    Senior Member
    vertical horizons's Computer Details
    Windows 7
    Gateway NV79
    Mechanical
    vertical horizons's Discipline Details
    Drafting Supervisor
    Mechanical
    Inventor 2013
    Mar 2010
    Texas
    172
    Quote Originally Posted by Dana W View Post
    ... I'd also make the grid a block so you can share it with friends.
    Good idea.
    Make sure that you use the WBLOCK (World Block) command, instead of the BLOCK command. That way, everyone can use it.
  6. #6
    Super Member
    AutoCAD pre 2000
    Nov 2008
    578
    Quote Originally Posted by vertical horizons View Post
    Good idea.
    Back a few years earlier, WBLOCK used to be referred to as WriteBlock. A term so mentioned in my official Acad manual. I think same effect, but new verbage.
    Wm.
  7. #7
    Senior Member rvpas's Avatar
    rvpas's Computer Details
    xp pro
    laptop HP Compaq nx9420 - workstation hp
    Architectural
    rvpas's Discipline Details
    building CAD designer and AUTOCAD ATC instructor free lance
    Architectural
    Help to design building with architect work with REVIT and AUTOCAD during the step of conception, follow the contruction site, building survey. ATC Instructor with trainng center 2d 3d AUTOCAD and REVIT
    AutoCAD 2012
    Apr 2010
    Savigny sur orge - south of paris
    172
    Hi everyone,
    You can use Hatch as Pablo said but not with predefined type
    You going to use User defined type.
    command : h
    Type and pattern :
    Type --> click on little arrow and select User defined (That allows to define a grid with personalized scale)
    Angle and scale :
    Angle --> 0
    Check Double (to create a grid with a same space for X and Y)
    Spacing --> 0.5 if your units is meter
    50 if your units is centimeter
    500 if your units is millimeter
    tips : normaly you cant use object snap on hatch, to change that, you can change a system variable OSOPTIONS set 2 or
    OPIONS "op"/Drafting tab
    Object Snap Options :
    uncheck Ignore hatch objects
    Bye
    Pascal
  8. #8
    Full Member
    AutoCAD 2008
    Jun 2009
    97
    Why do we need a shortcut to make a grid??? It's the easiest thing to create.
  9. #9
    Junior Member
    not applicable
    May 2010
    11
    just because when im trying to make several different drawings with different hatches in different scales for different clients, its nice to have shortcuts. i just ended up using the array command and making it a few different blocks, in a few different scales. still have to tweek sometimes but good enough.
  1. Grids and Dimensions
    By Mr Smith 33 in forum Revit General
    Last Post: 23rd Feb 2010, 12:14 pm
  2. want to make a simple box with grids in it
    By flipper16 in forum AutoCAD General
    Last Post: 15th May 2009, 05:00 pm
  3. CAD X,Y co-ords and OS grids
    By yrmuser in forum AutoCAD Drawing Management & Output
    Last Post: 11th Feb 2008, 02:49 pm
  4. Looking for help generating grids
    By gedster in forum AutoCAD General
    Last Post: 19th Mar 2007, 10:50 pm
  5. Coordinates and Grids
    By StevePaul in forum AutoCAD Drawing Management & Output
    Last Post: 18th Feb 2006, 01:21 am
