Display Problem
crazylanemike
Post your system specs.
What is the size of the file you're working on?
Is the problem confined to just this one drawing or any drawing you work with?
Are there any attached xrefs?
Autocad 2008 MEP
File size 4 megs
Does it to all drawings
No Xrefs are attached just loaded
My computers power supply went out a couple of weeks a go and after it got fixed it started giveing me this problem
The Specs
Microsoft windows XP professional version 2002
service Pack 2
Dell Precision PWS 690
Intel® Xeon® CPU
E5320 @ 1.86GHz
1.86GHz 3.25GB Ram
If you need more info just let me know what
Thanks
What do you have in there for a graphics card? Is it a nVidia Quadro FX550?
The Precision PWS 690 is a workstation class computer. Even with a 4MB drawing file you should not be experiencing any problems when switching views.
Set regenmode to 0.
I have a feeling that changing views is one of those commands that triggers an auto regen. I sometimes get a 5 sec delay when using the Dist command too, but with tool tips on, it tells me what it's doing.
