Olly Posted June 18, 2010 Share Posted June 18, 2010 My drafting settings have changed somehow. I may have accidentally pressed a wrong key or 2010 is just glitching and it changed my preferences. Before, I would select a line, press (e), (spacebar) and it would erase a line. Now, I do the same thing but am then forced to "select object" before pressing (spacebar) again to erase. This applies to almost all commands, where the order is reversed. I have to press the hotkey first, and then select the object to do that command. This is especially annoying. I have also lost my "draw order" option when I right-click with an entity selected. If anyone has a clue to what's going on and how to reset my settings, your help would be greatly appreciated! I don't really mind resetting everything to default settings. Cheers, R Quote Link to comment Share on other sites More sharing options...
Olly Posted June 18, 2010 Author Share Posted June 18, 2010 ...And it has magically fixed itself... I didn't do a thing... wtf? Quote Link to comment Share on other sites More sharing options...
Dana W Posted June 18, 2010 Share Posted June 18, 2010 Do you have Right Click Customization time interval set real short? Maybe you were just not beating the clock? Quote Link to comment Share on other sites More sharing options...
nukecad Posted June 18, 2010 Share Posted June 18, 2010 Sounds like the old problem of the PICKFIRST variable being changed to 0 by a lisp and not reset. Quote Link to comment Share on other sites More sharing options...
