nicnicman Posted June 20, 2010 Share Posted June 20, 2010 After creating a simple 3d model of a house I have arranged 4 viewports to show 4 different views of the house. I'm using the autocad default SW, SE, NE, and NW Isometric views to show the entire building on one sheet. My problem is that I do not like the camera angle of these default views. It seems to high. I can manually alter each view with ORBIT, but I would like for the camera angle to be consistent on each view. Is there a setting I can change to alter the Isometric camera view consistently between each viewport so as to make it shoot from a lower vantage point? Any suggestions are appreciated! Quote Link to comment Share on other sites More sharing options...
SEANT Posted June 20, 2010 Share Posted June 20, 2010 The VPOINT command allows precise changes to the view direction. AutoCAD’s SW iso, for example, could be recreated with Command: [color="Green"]_vpoint[/color] Current view direction: VIEWDIR=0.0000,0.0000,1.0000 Specify a view point or [Rotate] <display compass and tripod>: [color="green"]-1,-1,1[/color] Regenerating model. A view from a similar direction, but with a lower vantage point, would be created by reducing the Z value (i.e., -1,-1,0.75). Quote Link to comment Share on other sites More sharing options...
nicnicman Posted June 20, 2010 Author Share Posted June 20, 2010 Thanks for the tip. It worked great! Quote Link to comment Share on other sites More sharing options...
