mcjohn Posted June 21, 2010 Share Posted June 21, 2010 In AutoCAD Civil 3D 2010 how can I label contours on a surface of just major contours? If I turn off minor contours and draw a line through the desired area and set an interval distance between labels, then autocad labels the major contours but once I turn minors back on again all contours are now labeled. There must be a way to label just majors while having major and minor contours showing? Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 21, 2010 Share Posted June 21, 2010 It's going to label any contour that intersects your label line. Just set the minor labels to a style that doesn't display, freeze the layer the minor labels would be on or set the display to off for the minor labels. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted June 21, 2010 Share Posted June 21, 2010 Select the contour label(s). You can turn off the minor contour labels in Properties. Quote Link to comment Share on other sites More sharing options...
mcjohn Posted June 21, 2010 Author Share Posted June 21, 2010 Thank you! Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 21, 2010 Share Posted June 21, 2010 Select the contour label(s). You can turn off the minor contour labels in Properties.or that Quote Link to comment Share on other sites More sharing options...
