Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Forum Newbie
    AutoCAD 2009
    Jun 2010
    7
    Default AutoLISP Triming everything on one side of a line
    I am looking a way to trim everything sticking out on one side of a line, and if possible select lines that need to be all extended to the other side of the line. I am working on a really large file that needs a lot of editing with trim on one side of the line and extending all the line on the other side of the line. If anybody can help i would really really appreciate it.
    Thank You
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,011
    Express Tools: EXTrim
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
    Forum Newbie
    AutoCAD 2009
    Jun 2010
    7
    Im not sure how that command works because i tried it and it still left a few things untrimed even tho when i use the trim command it gets trimmed
    Civil 3D 2011
    Apr 2008
    6,011
    EXTRIM.gif...........
  5. #5
    Forum Newbie
    AutoCAD 2009
    Jun 2010
    7
    Default To much trimming, need an easier way of doing this
    oh wow thank you so much, i finally figured it with your help. Nice Video!
    Do you have any ideas of how i can make a messy file with many lines overlapping into a clean file with zero lines overlapping?
    I also attached a jpg of the drawing that im working on and i am trying to make the edges of the street blocks straight because they were imported using another program and they came out very crooked. Do you have an easy method of doing this?
    Right now i am trimming away and i only showed you a small clip of the whole drawing. There are line 15-20 blocks with about 45-60 lots on each block.
    If you have any idea how i can make this process go faster i would greatly appreciate it.
    Thanks for the help
    Feliks
  6. #6
    Senior Member
    Map 3D 2008
    Apr 2009
    The one after 909
    402
    I do this sort of stuff at my work (road edges, lot lines, etc) and from my experience, it's best to just accept that it'll never be straight I think most of that data is obtained by satellite or from ancient records, and I seriously doubt anyone who had a hand in creating the file cared much about making nice neat straight lines that looked super pretty. For what it's worth, it irks me to no end as well.
    If you absolutely must make them straight, you could draw a polyline or xline to approximate it, and then manually move all the points to that line, or just use that line to trim out the spots that are screwy. There may be some complex way of speeding up that process, but I wouldn't know how. The only other thing I could think to suggest would be to re-think how you're importing it, but that's a long shot.
    ~* And, in the end, the love you take *~
    ~* Is equal to the love you make *~
    - The Beatles -
    GrPlayground
    / Text Find/Replace / Batch Engine / Tower Defense
  7. #7
    Civil 3D 2011
    Apr 2008
    6,011
    I agree. GIS, etc. data is just ugly as hell.
    This is the best I could come up with:
  8. #8
    Senior Member
    Map 3D 2008
    Apr 2009
    The one after 909
    402
    How'd you manage that, Alan? I struggled for days trying to figure out a linear least squares formula (the ultimate goal was to get it done for a circle, but I still can't figure that one out).
    - The Beatles -
    GrPlayground
  9. #9
    Civil 3D 2011
    Apr 2008
    6,011
    It's doesn't do anything fancy like that. It just removes all interior segments, so the LWPolyline is a single segment curve.
    What're you trying to do? I'm not fully understanding.
  10. #10
    Forum Newbie
    AutoCAD 2009
    Jun 2010
    7
    Default Thanks for the reply
    Really thats funny that you have to do the same. Well the only problem with accepting it is that after i import all the lots and streets and road etc. i have to hatch each item seperately, the roads, the building footprints, and the streets. To do that i need some kinda of boundary and its really difficult to get an easy boundary from the imported files. Anyways if you have any idea about hatching it easier let me know
  1. dimensioning all crossing lines or ... in one side of a selected line!!!
    By kasra in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Apr 2010, 04:25 am
  2. Help drawing a curve side to side inside a rectangle
    By berol in forum AutoCAD Beginners' Area
    Last Post: 10th Apr 2010, 05:45 pm
  3. pline with 1 side hidden & 3 sides cont'' but all as 1 joined line
    By stevsmith in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Feb 2010, 11:28 am
  4. application Failed...because its side-by-side configuration
    By Riverfriends in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 4th Aug 2009, 01:56 pm
  5. Triming line to blocks VBA
    By Figment in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Aug 2007, 10:51 pm
