Hi all,
I have a set of drawings with a block for the structure that is x-clipped differently on each plan.
The problem is that when i reference the plans into antoher drawing, the block for the structural drawings comes unclipped, so columsn that should't be seen on that elvel actually appear.
In the original drawings the clip of the block is correct and yaou only see the columns you shoudlsee on each level...
Any ideas?
Thansk!
