Results 1 to 10 of 10
    Junior Member
    AutoCAD LT 2007
    Jun 2010
    10
    Default Extrating attributes
    Hi Im trying to extract an attribute block to get the employees name, desk number and floor and have put the info below into a template file. I type ATTEXT into the command line and try to extract a CDF file into another text file. When i go to that extracted file the file is blank.
    BLK_EMPLOYEE C016000
    BLK_NUMBER C005000
    BLK_FLOOR C004000
    Not sure why it puts a smiley face in. it should have : D where the face is
    Can someone help? please?
    Nath
    Senior Member rvpas's Avatar
    rvpas's Computer Details
    xp pro
    laptop HP Compaq nx9420 - workstation hp
    Architectural
    rvpas's Discipline Details
    building CAD designer and AUTOCAD ATC instructor free lance
    Architectural
    Help to design building with architect work with REVIT and AUTOCAD during the step of conception, follow the contruction site, building survey. ATC Instructor with trainng center 2d 3d AUTOCAD and REVIT
    AutoCAD 2012
    Apr 2010
    Savigny sur orge - south of paris
    172
    Hi Nath,
    If my souvenirs are well you have to add at the beginning the name of the block
    BL:Name of block C015000
    K_EMPLOYEE C016000
    K_NUMBER C005000
    K_FLOOR C004000
    Bye
    Pascal
    Junior Member
    AutoCAD LT 2007
    Jun 2010
    10
    Thanks RVPAS
    This is what i am putting in the Template file (see below) but i still get a blank file in the out put file?
    BLK_NUMBER C005000
    BLK_FLOOR C004000
    the employee charactors have about 20 charactors max, the number has 5 max and floor has 3. Can you see anything wrong
    Junior Member
    AutoCAD LT 2007
    Jun 2010
    10
    Sorry it keeps putting a smiley face in the smiley should be : D with no space
  5. #5
    xp pro
    Architectural
    Architectural
    AutoCAD 2012
    Apr 2010
    172
    Do you have an attribute inside your block ?
    Pascal
    PS Could you post your extraction file and a part of your drawing ?
  6. #6
    Junior Member
    AutoCAD LT 2007
    Jun 2010
    10
    I think so. im trying to extract the following
    Nathan Hastings
    G1034
    GFO
    I can seem to attach either the drawing or template file using this forum?
  7. #7
    xp pro
    Architectural
    Architectural
    AutoCAD 2012
    Apr 2010
    172
    If K_EMPLOYEE, K_NUMBER, K_FLOOR is your attributes
    What's a name of your block ?
  8. #8
    Junior Member
    AutoCAD LT 2007
    Jun 2010
    10
    The layer is called workstations
    Not sure what you mean by block?
  9. #9
    xp pro
    Architectural
    Architectural
    AutoCAD 2012
    Apr 2010
    172
    A block is component of library like you workstation
    and in your extract file I do not see the name of the block
    dont confuse with layer it's different.
    BL:workstation C015000 (workstation is name of block)
    K_EMPLOYEE C016000 (Attribute)
    K_NUMBER C005000 (Attribute)
    K_FLOOR C004000 (Attribute)
    see drawing example attached
    last solution send me your drawing to my email (rvpas@aol.com) if you want ?
  10. #10
    xp pro
    Architectural
    Architectural
    AutoCAD 2012
    Apr 2010
    172
    Hi Nathan,
    I was not able to answer earlier because having no version LT, I had to download one. But I have confirmation of your error now.
    When you specified the name of the block in your file of extraction, autocad does not manage to read the name of the block with spaces
    You owe, either to delete spaces or to place - or _ between every name
    And also rename your block.
    Have a nice day
    Pascal
  1. Attributes
    By happyunited in forum AutoCAD General
    Last Post: 21st Aug 2009, 01:47 pm
  2. Attributes (again)
    By merdrignac in forum AutoCAD General
    Last Post: 26th Nov 2008, 02:39 pm
  3. vba Attributes
    By dave buckberry in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Nov 2008, 07:11 pm
  4. Attributes
    By flowerrobot in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Sep 2008, 07:11 am
  5. attributes
    By chrisdarmanin in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2007, 03:07 pm
