Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    Senior Member CJJ's Avatar
    CJJ's Computer Details
    Windows XP
    Old, Slow, Full of porn.
    Civil 3D 2009
    Nov 2009
    North Carolina
    137
    Default Invalid URI Error Message
    I have had two of our company's AutoCAD users report a similar message. Both of them seem to have gotten this on Friday, and every time they open AutoCAD this happens. The message pops up showing an error, and when you click Continue, everything seems to be working.
    I've googled the message, and couldn't find much information that applies to AutoCAD. I think the "URI" message means there is a problem in Mircosoft .NET Framework, but that's about all I can get from it.
    I was just wondering if anyone had seen a similar message, or has any idea how to fix the problem. I apologize for the long post, but I'm going to paste the full details of the error messages.
    Unhandled Exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
    Invalid URI: The format of the URI could not be determined.
    One is using Civil 3D 2009, and gets the following under details:
    Code:
    Application does not support just-in-time (JIT)
    debugging. See the end of this message for details.
    ************** Exception Text **************
    System.UriFormatException: Invalid URI: The URI scheme is not valid.
       at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
       at System.Uri..ctor(String uriString)
       at Autodesk.InfoCenter.CommunicationCenter.PopulateContents(ResultItemCollection& contentCollection, ICommCntrChannel channel)
       at Autodesk.InfoCenter.CommunicationCenter.GetContents(ResultItemCollection& channelContents)
       at Autodesk.InfoCenter.CommCntrSource.InitCommunicationCenter()
       at Autodesk.InfoCenter.PaletteMgr.get_CommCntrSrc()
       at Autodesk.InfoCenter.PaletteMgr.LoadCommCenterSources()
       at Autodesk.InfoCenter.PaletteMgr.InitCommCenter()
       at Autodesk.InfoCenter.PaletteMgr.InitSources()
       at Autodesk.InfoCenter.PaletteMgr.FirstInvoke()
       at Autodesk.InfoCenter.PaletteMgr.OnAppIdle(Object sender, EventArgs e)
       at System.Windows.Forms.Application.RaiseIdle(EventArgs e)
       at Autodesk.AutoCAD.ApplicationServices.Application.OnIdleWinForms()
       at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.50727.3603 (GDR.050727-3600)
        CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    acdbmgd
        Assembly Version: 17.2.0.0
        Win32 Version: 17.2.711.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AcdbMgd.DLL
    System
        Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    msvcm80
        Assembly Version: 8.0.50727.3053
        Win32 Version: 8.00.50727.3053
        CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca/msvcm80.dll
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Xml
        Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    PresentationFramework
        Assembly Version: 3.0.0.0
        Win32 Version: 3.0.6920.1500 built by: QFE
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
    WindowsBase
        Win32 Version: 3.0.6920.1427 built by: SP
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
    PresentationCore
        CodeBase: file:///C:/WINDOWS/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
    acmgd
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/acmgd.DLL
    AdWindowsWrapper
        Win32 Version: 17.2.56.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AdWindowsWrapper.DLL
    AdWindows
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.711.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AdWindows.DLL
    ResourceManagement
        Assembly Version: 12.0.76.0
        Win32 Version: 12.0.076.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/ResourceManagement.DLL
    AdWindows.resources
        Win32 Version: 1.0.56.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/en-US/AdWindows.resources.DLL
    PresentationFramework.Classic
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Classic/3.0.0.0__31bf3856ad364e35/PresentationFramework.Classic.dll
    AcMgdReverse
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AcMgdReverse.DLL
    Redland.NET
        Assembly Version: 1.0.2.1
        Win32 Version: 1.0.2.1
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/Redland.NET.DLL
    AcInfoCenterConn
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AcInfoCenterConn.DLL
    AdInfoCenter
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AdInfoCenter.DLL
    AcWindows
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AcWindows.DLL
    AdInfoCenter.resources
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/en-US/AdInfoCenter.resources.DLL
    Accessibility
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Configuration
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Web.Services
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
    Autodesk.Interop.WSCommCntr1
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/Autodesk.Interop.WSCommCntr1.DLL
    Microsoft.JScript
        Assembly Version: 8.0.0.0
        Win32 Version: 8.0.50727.3053
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll
    ************** JIT Debugging **************
    Application does not support Windows Forms just-in-time (JIT)
    debugging. Contact the application author for more
    information.
    Windows XP
    Civil 3D 2009
    Nov 2009
    North Carolina
    137
    The second user is using Map 3D 2009, and this is what the details shows
    Code:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    System.UriFormatException: Invalid URI: The format of the URI could not be determined.
       at Autodesk.InfoCenter.PaletteMgr.InitPalettes()
       at ?A0x2b7cf235.OnIdle()
    mscorlib
    acdbmgd
        Assembly Version: 17.1.0.0
        Win32 Version: 17.1.219.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AcdbMgd.DLL
    ResourceManagement
        Assembly Version: 11.0.79.0
        Win32 Version: 11.0.079.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/ResourceManagement.DLL
    msvcm80
    acmgd
        Win32 Version: 17.1.51.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/acmgd.DLL
    AecDtlDb
        Assembly Version: 5.5.256.0
        Win32 Version: 5, 5, 256, 0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AecDtlDb.DLL
    AecDtlDbUI
        Win32 Version: 5.5.256.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AecDtlDbUI.DLL
    AecDtlDbLib
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AecDtlDbLib.DLL
    Redland.NET
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Redland.NET.DLL
    AcInfoCenterConn
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AcInfoCenterConn.DLL
    AdInfoCenter
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AdInfoCenter.DLL
    System
    System.Drawing
    Autodesk.Interop.AcInetEngine
        Assembly Version: 17.1.51.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Autodesk.Interop.AcInetEngine.DLL
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/en-US/AdInfoCenter.resources.DLL
    Accessibility
    System.Xml
    ii5ogyiu
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Autodesk.Interop.WSCommCntr1.DLL
    Autodesk.Interop.WebServices1
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Autodesk.Interop.WebServices1.DLL
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT de****** registered on the computer
    rather than be handled by this dialog box.
    Forum Newbie
    AutoCAD 2011
    Jul 2010
    3
    Default Similar experience
    Hi
    No solution to this URI problem, but I have 8 users in one of our locations in Finland who just now reported this incident. I am also googling around for help.
    These users have AutoCad 2008 LT
    Forum Newbie
    AutoCAD 2011
    Jul 2010
    3
    Default Framework updates reason?
    I noticed that on the 28.6 I have received following updates:
    Microsoft NET Framework 2 Service Pack 2 - KB976576
    Microsoft NET Framework 2 Service Pack 3 - KB977354
    I asked our designers having the problem to remove updates and see if that helps
  5. #5
    Forum Newbie
    AutoCAD 2011
    Jul 2010
    3
    Default problem not solved
    it wasn't that easy - still looking for a solution
  6. #6
    Forum Newbie
    AutoCAD LT 2009
    Jul 2010
    1
    My AutoCAD Lt 2009 was working fine this morning, installed the latest i-tunes 9.2 (64bit) then started getting the URI error. Will try and uninstall that to see if it works, but cant imagine why i-tunes will affect autocad.
    EDIT - Uninstalled i-tunes and the URI error has gone and my autocad is working normally. Strange.
  7. #7
    Forum Newbie
    Civil 3D 2010
    Apr 2010
    1
    I have just started encountering this error as well. Although none of my system settings have changed. No programs or updates were installed either. I am using Civil 3D Land Desktop Companion 2008, so I'm guessing by this thread that it's not limited to one certain deployment.
  8. #8
    Forum Newbie
    AutoCAD LT 2008
    Aug 2010
    1
    Default Same URI problem
    Quote Originally Posted by mela2010 View Post
    Hi
    I am using AutoCAD 2008 LT & have started receiving the same error. Any resolution yet? Thank you.
  9. #9
    Windows XP
    Civil 3D 2009
    Nov 2009
    North Carolina
    137
    Just had another user get this URI error yesterday, this time with AutoCAD Map 3D 2008.
    Still no ideas about where it comes from/how to fix it. However, the good news is that the Civil 3D '09 user's message has gone away (on its own). I don't know what changed on his system, but it's possible that a patch from Microsoft may have had something to do with it, but I don't know.
  10. #10
    Forum Newbie
    AutoCAD 2010
    Aug 2010
    1
    Myself and one other user received this error today as well. We are both running AutoCAD 2008. I am running 2010 concurrently and it have not had the error. The other guy who had the issue stated that he saw his machine performing a windows update when he booted up this morning.
  1. custom linetype (invalid number - bad continuation) error
    By samla02 in forum AutoCAD Drawing Management & Output
    Last Post: 17th Nov 2010, 12:47 am
  2. invalid load message from design centre
    By michaeloureiro in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jan 2009, 04:52 pm
  3. *Invalid* DB Insertion Error
    By GE13579 in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jun 2008, 10:40 am
  4. Error message
    By staps in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 3rd Mar 2006, 06:22 pm
  5. Pop up Error message
    By Big Mike in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2006, 04:20 pm
