Results 1 to 7 of 7
    Full Member bleeargh's Avatar
    bleeargh's Computer Details
    windows 10
    Homemade Rig. Purchased all components from Newegg
    Intel i7 2600k CPU @ 3.40GHz
    8 GB
    Nvidia Geforce GTX 670
    1 Terrabyte
    1 Terrabyte
    Architectural
    bleeargh's Discipline Details
    Freelance Drafter
    Architectural
    My background is mostly in commercial architecture. I left "dilbertland" in 2005 and have been doing freelance ever since. I mostly do (and really enjoy) residential design.
    AutoCAD 2017
    Oct 2005
    South Dakota - USA
    75
    Default Autosum function?
    One of my clients is an electrical engineer. When he is designing his circuit panels he has to add up the amps of each individual circuit and make sure he specs out the correct amperage on his panel box. He was wondering if I could figure out a way for AutoCAD to automatically add up the individual circuit amps and give him an automatic total. Similar to the autosum function in the Microsoft Excel program. Is this possible?
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,541
    It is possible to do but it would take a very specific set of rules and good bit of custom automation. -David
    R12 (Dos) - A2K
    windows 10
    8 GB
    1 Terrabyte
    1 Terrabyte
    Architectural
    Freelance Drafter
    Architectural
    AutoCAD 2017
    Oct 2005
    South Dakota - USA
    75
    Thanks for the reply. When talking about "a very specific set of rules" and "custom automation" are we talking about writing specialized lisp routines and such? Could you be more specific?
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    2,541
    Yes, that would be the approach that I would use.
    If a block where created with attributes such a panel number, circuit number, amperage rating, voltage and phase, shunt trip breaker needs etc. and attached it to each circuit, you could go in add everything up for a specified panel. Along with total number of spaces required, total amperage, I guess you could even try to calclate the load balances and or make a panel schedule with the best case scenario. A pretty in depth project. -David
    R12 (Dos) - A2K
  5. #5
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    It could be a fairly simple lisp routine if rather than "automatic", the user selects the text items to total, and selects the text to edit to show the total. I've heard that with 2006 you can use formulas in Fields, which could probably perform an "Autosum".
  6. #6
    windows 10
    8 GB
    1 Terrabyte
    1 Terrabyte
    Architectural
    Freelance Drafter
    Architectural
    AutoCAD 2017
    Oct 2005
    South Dakota - USA
    75
    I have already created an attribute panel schedule. It's pretty much to the point of data entry. It prompts you for every aspect needed in the panel schedule. My knowledge ends when it comes to taking the information in an attribute and adding creative little functions to them, such as the afor mentioned sum function. Is there a online tutorial somewhere that gives an idea how to do this? Or am I resigned to digging out my useless AutoCAD manual? I appreciated the post CarB, however my client probably would prefer the autosum upon the data entry rather than the selection method. I neglected to say, I am using AutoCAD 2005, he is on 2004.
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD pre 2000
    Dec 2003
    2,541
    Adding a list of string values together is fairly easy:
    Code:
    (apply '+ (mapcar 'atof '("12.3" "33.3" "6.0")))
    Should return 51.6
    So if you can extract the attribute's string values into a list you can do it.
    There would ba a lot of things check
    • Panel name
    • Phase leg
    • Is the string all numeric characters
    • Yada yada yada
    For a 3 phase panel, you would to do this three times, single phase twice. -David
    R12 (Dos) - A2K
