ovzka Posted June 29, 2010 Share Posted June 29, 2010 hi i recently install cad 2011 an i have and issue :wink: in cad 2010 i make several lines and make extrude, after this i make a loft to this planes to converted to a solid in cad 2011 this "solid" its empty its missing some faces so its not a solid ¿ its there a way to fix this? sorry for my English Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2010 Share Posted June 29, 2010 I'm trying to figure out why you need to extrude first then loft. The object on the left can be created as a solid using extrude or press/pull. I'm not sure what you are trying to accomplish on the right. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2010 Share Posted June 29, 2010 An approximation of one of your objects created with the press/pull command (on left). To the right is a copy of the object that has been sliced to prove it is a solid. Quote Link to comment Share on other sites More sharing options...
ovzka Posted June 29, 2010 Author Share Posted June 29, 2010 tnx:) i know about press/pull but what if i need to do this? (cad2011.jpg) to reach this (fachada principal (2).jpg and fachada oeste diurna.jpg) some times i need to do this proceeder:cry: Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2010 Share Posted June 29, 2010 Thank you your explanation. Now I see what you are attempting to do. What I still confused about is the method you are using to go about achieving the affect. Are you using lofting the planes using the curves as your guides? Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2010 Share Posted June 29, 2010 I gave it another try using the method I asked you about in my previous post. The image below shows three views of the entire object I created along with one view after I sliced it to prove I created a solid. Quote Link to comment Share on other sites More sharing options...
ovzka Posted June 29, 2010 Author Share Posted June 29, 2010 i dont use the curves as guides in your profile says that you are using cad 2010 this issue is in 2011 is your profile wrong? I was thinking about returning to cad 2010 your image its dificult to understand for me : did you 3rotate? or view from below? if you are in cad 2011 could you tell me exactly what yo do? i am frustrated i have years doing this preceder and i have never have problems Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2010 Share Posted June 29, 2010 I shall correct my previous statement. I extruded four lines to create surfaces. Then I did a loft of two curves lines (one on each side of the planes). I used the four planes as my guides. My profile is correct. All work was done in plain AutoCAD 2010. Although I am on subscription I have not loaded 2011. I usually wait 3 full months before loading the newest release in order to catch the first update (service pack) that addresses many of the problems users encounter with new releases. I did not 3Drotate. The original object, in the lower right hand corner, was copied three times. Two of those copies were rotated using the normal Rotate command. The third copy (that I ended up slicing) was made in the same orientation as the original. You say you have done this in the past. Could you explain how you did it, if it differs from my technique, and go into a bit more detail? My goal was to try to reproduce what you were attempting to do so I could get a better idea of 1) how it was done and 2) what possible problems could occur. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2010 Share Posted June 29, 2010 Another example. Perhaps the color differences will help make things easier to understand. Polylines are in red, lines in black. Quote Link to comment Share on other sites More sharing options...
ovzka Posted June 29, 2010 Author Share Posted June 29, 2010 now i getit i make several lines and make extrude, after this i make a loft to this planes to converted to a solid i don't use curves Quote Link to comment Share on other sites More sharing options...
ovzka Posted June 29, 2010 Author Share Posted June 29, 2010 i triad like yo did but doesn't make the solid, is still empty Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 30, 2010 Share Posted June 30, 2010 You don't use curves? That's funny. Two of your examples have curves in them. There is no "conversion" to a solid. In the process I used the solid is created when the curves were lofted. I did not create a surface first then convert it to a solid. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 30, 2010 Share Posted June 30, 2010 Post you're drawing so we can take a look at it. First save it down to a previous version. Do a "save as" in 2007 file format. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 30, 2010 Share Posted June 30, 2010 Try this simple exercise on your computer. Draw four lines as you see them in number 1. Extrude the front and back lines making the back taller as you see in number 2. Make a copy of the objects you just created. Start the Loft command. When AutoCAD prompts you to Select cross sections in lofting order pick the back plane and the front plane you created with the Extrude command. When AutoCAD prompts you to Enter an option [Guides/Path/Cross sections only] : type the letter "G" and then press Enter. Now select the two remaining lines that were not extruded. AutoCAD refers to these lines as Guide curves even though they are straight. The finished result should appear as number 3. Doing a "List" on this object will confirm it is a true 3Dsolid. Quote Link to comment Share on other sites More sharing options...
ovzka Posted June 30, 2010 Author Share Posted June 30, 2010 i added a 4° object i only select in the green circle and move so you cant see its empty wen i say i don't use curves i mine the guide curves you use (dash red ones) Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 30, 2010 Share Posted June 30, 2010 Please do me a favor. After you have completed the steps you took to create the above object would you press the F2 function key, bring up the AutoCAD text screen, copy the AutoCAD commands and your responses and post them here. Thank you. By the way, if you use the loft command and just select the front and back planes (ignoring the lines) you should still end up with a solid. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 30, 2010 Share Posted June 30, 2010 One more favor if I may. Do a list on the last object to the right in the image above (the one that is open). Does the object description come back as a Lofted Surface because that is what it looks like you have created to me. Quote Link to comment Share on other sites More sharing options...
Bobzy20 Posted June 30, 2010 Share Posted June 30, 2010 Hi ReMark I just followed your little tutorial above (4 posts above) and at the end the 2 extruded items weren’t part of the solid. I can delete them and the item is hollow. Is that right? Thanks Bobzy20 Quote Link to comment Share on other sites More sharing options...
ovzka Posted July 1, 2010 Author Share Posted July 1, 2010 that is my problem loft in cad 2011 does not create a solid Quote Link to comment Share on other sites More sharing options...
ovzka Posted July 1, 2010 Author Share Posted July 1, 2010 Customization file loaded successfully. Customization Group: ACAD Customization file loaded successfully. Customization Group: CUSTOM Customization file loaded successfully. Customization Group: EXPRESS Regenerating model. AutoCAD menu utilities loaded. Command: _RIBBON Command: COMMANDLINE Command: Layer Command: properties Command: Command: Regenerating model. Command: l LINE Specify first point: Specify next point or [undo]: Specify next point or [undo]: Command: LINE Specify first point: Specify next point or [undo]: Specify next point or [undo]: Command: co COPY Select objects: Specify opposite corner: 2 found Select objects: Current settings: Copy mode = Multiple Specify base point or [Displacement/mOde] : Specify second point or : Specify second point or [Exit/Undo] : Command: ext EXTRUDE Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid Select objects to extrude or [MOde]: Specify opposite corner: 2 found Select objects to extrude or [MOde]: Specify height of extrusion or [Direction/Path/Taper angle/Expression]: *Cancel* Command: ext EXTRUDE Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid Select objects to extrude or [MOde]: Specify opposite corner: 1 found Select objects to extrude or [MOde]: Specify height of extrusion or [Direction/Path/Taper angle/Expression]: Command: EXTRUDE Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid Select objects to extrude or [MOde]: Specify opposite corner: 1 found Select objects to extrude or [MOde]: Specify height of extrusion or [Direction/Path/Taper angle/Expression] : Command: co COPY Select objects: Specify opposite corner: 3 found Select objects: Current settings: Copy mode = Multiple Specify base point or [Displacement/mOde] : Specify second point or : Specify second point or [Exit/Undo] : Command: loft Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 2 total Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 2 cross sections selected Enter an option [Guides/Path/Cross sections only/Settings/COntinuity/Bulge magnitude] : C Command: co COPY Select objects: 1 found Select objects: Current settings: Copy mode = Multiple Specify base point or [Displacement/mOde] : Specify second point or : Specify second point or [Exit/Undo] : Command: z ZOOM Specify corner of window, enter a scale factor (nX or nXP), or [All/Center/Dynamic/Extents/Previous/Scale/Window/Object] : e Command: sha SHADEMODE VSCURRENT Enter an option [2dwireframe/Wireframe/Hidden/Realistic/Conceptual/Shaded/shaded with Edges/shades of Gray/SKetchy/X-ray/Other] : r Quote Link to comment Share on other sites More sharing options...
