+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Senior Member
    Computer Details
    paul1966's Computer Details
    Operating System:
    win 7 pro
    Motherboard:
    ASRock AM2NF3-VSTA
    CPU:
    AMD Sempron 3400+ 1.81Ghz
    RAM:
    3 GB
    Graphics:
    NVIDIA Quadro FX1000
    Primary Storage:
    Maxtor 80 GB
    Monitor:
    Samsung 2232BW 22 inch wide screen + 22inch TFT
    Discipline
    HVAC
    Using
    AutoCAD 2010
    Join Date
    Dec 2007
    Location
    Leicester, UK
    Posts
    162
    Default world ucs rotated
    i have a drawing i am using as an xref, the world ucs on the drawing is rotated so when i overlay the xref its not lined up with my drawing. had a quick look in the ucs menu but can not figure out how to rotate the world ucs back. Help!
  2. #2
    Luminous Being alanjt's Avatar
    Using
    Civil 3D 2011
    Join Date
    Apr 2008
    Posts
    5,985
    Default
    Type UCS and follow the prompts.
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  3. #3
    Senior Member
    Computer Details
    Operating System:
    win 7 pro
    Motherboard:
    ASRock AM2NF3-VSTA
    CPU:
    RAM:
    3 GB
    Graphics:
    Primary Storage:
    Maxtor 80 GB
    Monitor:
    Discipline
    HVAC
    Using
    AutoCAD 2010
    Join Date
    Dec 2007
    Location
    Leicester, UK
    Posts
    162
    Default
    still not sure?, in the ucs options if i select view the ucs rotates back to where i want it. i save the drawing and then attach it as an xref and its still rotated.
  4. #4
    Super Member RobDraw's Avatar
    Using
    AutoCAD 2011
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    1,210
    Default
    You're going to have to rotate one of your plans. First go to your XREF file and change your view to be oriented to world ucs from the "view" commmand. After that decide which plan you want to rotate, find the appropriate angle, and rotate.
    Rob
  5. #5
    Junior Member
    Using
    AutoCAD 2008
    Join Date
    May 2010
    Posts
    19
    Default
    Quote Originally Posted by paul1966 View Post
    To rotate the "World" you need to first set the ucs to world, this is done with ucs, press enter, world, press enter, then you have to use the command plan, press enter, then world or ucs (Which has world as reference), press enter, and you will have your view and reference system in World, ucs being the reference system and plan the view. I'm not sure if this was your question though. If you want to rotate only one of them (view or reference system) then you only have to do one of these 2 set of commands.
Similar Threads
  1. Rotated UCS leads to rotated Reference Files
    By BenGoble in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Apr 2010, 01:01 pm
  2. Need help- the drawing is rotated
    By MisterJingles in forum AutoCAD Beginners' Area
    Last Post: 21st Sep 2009, 03:32 pm
  3. Rotated Dimensions
    By sharonb in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Feb 2008, 09:18 pm
  4. Rotated Viewport
    By Skeeps in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2006, 09:53 am
  5. rotated WCS
    By Barry Clark in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Sep 2004, 04:36 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
